Instantiate Adafruit Screen objects
by chuckinfruit on Thu Aug 06, 2020 3:43 pm
Hi there ! I'm working on a multi spi oled screen to easy a bit my code I'd like to instantiate the Adafruit declaration of the different screen.
So far, I wrote something like :
Adafruit_SSD1331 display[PARAM_AMOUNT] = {Adafruit_SSD1331(&SPI, cs, dc, rst), Adafruit_SSD1331(&SPI, cs2, dc2, rst2)};
where PARAM_AMOUNT is 2 but even though it compiles, I get stuck when executing some of the methods. The program seems not to comply the method it's executing.
For instance, it gets stuck in the void setup function whenever I init with a for loop the screen like that:
for (int i = 0; i <= 1; i++){
    display[i].begin();
    display[i].fillScreen(BLACK);
Thanks for your help !
chuckinfruit
Re: Instantiate Adafruit Screen objects
by adafruit_support_bill on Thu Aug 06, 2020 3:57 pm
What processor are you using?
by chuckinfruit on Fri Aug 07, 2020 3:59 am
Hi, i'm using either a Teensy 4 or a Arduino Uno so MIMXRT1062 or ATMega328P.
chuckinfruit
by adafruit_support_bill on Fri Aug 07, 2020 5:59 am
Those are 2 very different processors. 2 displays on an UNO is likely to exceed the available memory. Are you seeing the same problem running on the Teensy?
by chuckinfruit on Fri Aug 07, 2020 7:50 am
Yes I actually checked on teensy. It did not work until this morning and things seem to run ok since then. I guess problem solved :)
chuckinfruit
by adafruit_support_bill on Fri Aug 07, 2020 8:13 am
Good to hear it is working. Thanks for the update.
