DPS310 Altitude Readings
by darbymotorsports on Fri Aug 07, 2020 3:41 pm
I am trying to get altitude readings from this sensor. Is there a function within Adafruit_DPS310.h or do I have to mathematically calculate based on pressure and temperature?
The example includes functions to pull temperature and pressure. Is there a list of functions and descriptions somewhere that will work?
This is the code from example,
// This example shows how to read temperature/pressure
#include <Adafruit_DPS310.h>
Adafruit_DPS310 dps;
// Can also use SPI!
#define DPS310_CS 10
Serial.begin(115200);
while (!Serial) delay(10);
Serial.println("DPS310");
if (! dps.begin_I2C(0x77)) { // Can pass in I2C address here, By default, the I2C address is 0x77.
//if (! dps.begin_SPI(DPS310_CS)) { // If you want to use SPI
Serial.println("Failed to find DPS");
while (1) yield();
Serial.println("DPS OK!");
dps.configurePressure(DPS310_64HZ, DPS310_64SAMPLES);
dps.configureTemperature(DPS310_64HZ, DPS310_64SAMPLES);
sensors_event_t temp_event, pressure_event;
while (!dps.temperatureAvailable() || !dps.pressureAvailable()) {
return; // wait until there's something to read
dps.getEvents(&temp_event, &pressure_event);
Serial.print(F("Temperature = "));
Serial.print(temp_event.temperature);
Serial.println(" *C");
Serial.print(F("Pressure = "));
Serial.print(pressure_event.pressure);
Serial.println(" hPa");
Serial.println();
darbymotorsports
Re: DPS310 Altitude Readings
by rick_sroka on Wed Aug 26, 2020 8:07 am
I was going to post that the program example on https://adafruit-circuitpython-dsp310.r ... /en/latest only show temp and Barometric not Altitude
rick_sroka
by adafruit_support_carter on Wed Aug 26, 2020 11:55 am
It looks like the libraries do not currently have an altitude function. So you'll have to do the math. Good info here:
https://learn.adafruit.com/clue-altimeter/overview
and the implementation in the BMP280 library may be helpful as a reference:
https://github.com/adafruit/Adafruit_BM ... 0.cpp#L373
by rick_sroka on Wed Aug 26, 2020 1:35 pm
ok can you change the info on the listings? i bought the unit for the altitude part.
rick_sroka
by siddacious on Wed Aug 26, 2020 7:11 pm
Adapting the code below is all that would be required to get an altitude from a pressure reading. You'll have to define the pressure at sea level in hPa.
  #define SEA_LEVEL_HPA <number here>
  float pressure = readPressure(); // in Si units for Pascal
  pressure /= 100;
  altitude = 44330 * (1.0 - pow(pressure / SEA_LEVEL_HPA, 0.1903));
I've created an issue on the library to add a function to do this within the library itself, however there isn't anything keeping you from deriving altitude measurements without it.
Feel free to voice your support here:
https://github.com/adafruit/Adafruit_DPS310/issues/3
siddacious
by rick_sroka on Wed Aug 26, 2020 8:26 pm
Hey thanks so much for the code. I am luck to add 1+1 to equals 2 some days
rick_sroka
by rick_sroka on Sun Sep 06, 2020 12:30 pm
Looks like the bug is fixed . How do I reload the driver on the raspberry pi?
rick_sroka
by siddacious on Tue Sep 08, 2020 2:11 pm
this should work:
pip install [package_name] --upgrade
if you previously installed with a "sudo" before "pip", you may need to add it to the above
siddacious
