Panel mount 9 v connector
by jag_man653 on Wed Aug 12, 2020 2:39 pm
I would like to provide a female 9 v connector mounted on my project enclosure. I got one at ShowMeCables.com but it doesn't fit, apparently because the center pin is larger than the center hole in the male connector on the 9v battery connector that came with my Arduino kit. However, there's no way I can measure the size of that pin since it's recessed.
Where can I find a panel mounted connector with the same dimensional specs as the connector on the UNO board?
jag_man653
Re: Panel mount 9 v connector
by jag_man653 on Wed Aug 12, 2020 4:27 pm
Solved my problem. The correct connector is Digi-Key SC3721-ND. It's a Power Barrel Connector Jack 2.10mm ID (0.083"), 5.50mm OD (0.217") Panel Mount. I Had ordered a couple a few days ago just on a hunch and they fit!
jag_man653
