MKR WiFi 1010 does not power up with battery.
by mesin on Tue Dec 15, 2020 10:02 pm
I'm trying to use the MKR WiFi 1010 with a 3.7V LiPo battery (3000 mAh), but it doesn't power up. The Arduino is also not charging the battery.
The Arduino is working fine (turns on and runs its script) when I connect it to a computer using a micro USB cable.
How can I have the Arduino to be powered by the battery? Is there a script that I must include to allow the Arduino to be operated by the battery?
Thank you.
mesin
Re: MKR WiFi 1010 does not power up with battery.
by tedmoore on Thu Jan 21, 2021 12:41 pm
I'm having this same problem. Did you find a solution?
tedmoore
by mikeysklar on Fri Jan 22, 2021 4:06 pm
I don't see any specific code being necessary to use the battery.
https://www.arduino.cc/en/Guide/MKRWiFi ... -batteries
The original post mentioned that the battery was not charging when plugged into the MKR WiFi 1010. What size LiPo are you using and how old is it? Do you see the charging indicator when both USB and battery are connected?
mikeysklar
by tedmoore on Sat Jan 23, 2021 11:50 am
Thank you for the reply. I discovered that the JST connected on my LiPo was the opposite of what the arduino wanted (+ and - switched). That was the problem! It's working great now that I know that. Thanks!
tedmoore
