Solar panel and battery recommendations for Arduino Uno
Re: Solar panel and battery recommendations for Arduino Uno
// Arduino Plant Disease Ecology Weather Station with Sleep Mode
// Available at https://github.com/jdetka/arduino_sensors/blob/main/digital_dht_fc-37_sleep_sd_rtc_201220.ino
#include <SD.h>
#include <Wire.h>
#include <dht.h>
#include "RTClib.h"
// how many milliseconds between grabbing data and logging it.
#define LOG_INTERVAL 600000 // mills between entries.
// how many milliseconds before writing the logged data permanently to disk
// set it to the LOG_INTERVAL to write each time (safest)
// set it to 10*LOG_INTERVAL to write all data every 10 datareads, you could lose up to
// the last 10 reads if power is lost but it uses less power and is much faster!
#define SYNC_INTERVAL 1000 // mills between calls to flush() - to write data to the card
uint32_t syncTime = 0; // time of last sync()
#define ECHO_TO_SERIAL 1 // echo data to serial port
#define WAIT_TO_START 0 // Wait for serial input in setup()
// Define temperature & relative humidity sensor DHT_11
dht DHT;
#define dhtPin 2 // Data Digital Pin 2
#define dhtPower 3 // Data Digital Pin 3
// Define wetness sensor FC-37 with potentiometer
#define leafPin 8 // Data Digital Pin 8
#define leafPower 9 // Power Digital Pin 9
RTC_PCF8523 RTC; // define the Real Time Clock object
const int chipSelect = 10; // Set to pin 10 for Arduino R3 Uno
// the logging file
File logfile;
void error(char *str)
Serial.print("error: ");
Serial.println(str);
// red LED indicates error
// digitalWrite(redLEDpin, HIGH);
while(1);
// Intial settings;
void setup(void)
Serial.begin(9600);
Serial.println();
pinMode(leafPower,OUTPUT);
pinMode(dhtPower, OUTPUT);
pinMode(LED_BUILTIN,OUTPUT);
digitalWrite(LED_BUILTIN,LOW);
digitalWrite(leafPower, LOW);
digitalWrite(dhtPower, LOW);
#if WAIT_TO_START
Serial.println("Type any character to start");
while(!Serial.available());
#endif //WAIT_TO_START
// initialize the SD card
Serial.print("Initializing SD card...");
// make sure that the default chip select pin is set to
// output, even if you don't use it:
pinMode(10, OUTPUT);
// see if the card is present and can be initialized:
if (!SD.begin(chipSelect)) {
error("Card failed, or not present");
Serial.println("card initialized.");
// create a new file
char filename[] = "LOGGER00.CSV";
for (uint8_t i = 0; i < 100; i++) {
filename[6] = i/10 + '0';
filename[7] = i%10 + '0';
if (! SD.exists(filename)) {
// only open a new file if it doesn't exist
logfile = SD.open(filename, FILE_WRITE);
break; // leave the loop!
if (! logfile) {
error("couldnt create file");
Serial.print("Logging to: ");
Serial.println(filename);
// connect to RTC
Wire.begin();
if (!RTC.begin()) {
logfile.println("RTC failed");
#if ECHO_TO_SERIAL
Serial.println("RTC failed");
#endif //ECHO_TO_SERIAL
logfile.println("datetime,lw,temp,rh");
#if ECHO_TO_SERIAL
Serial.println("datetime,lw,temp,rh");
// If I want to set the aref to something other than 5v
analogReference(EXTERNAL);
void loop(void)
DateTime now;
// delay for the amount of time we want between readings
delay((LOG_INTERVAL -1) - (millis() % LOG_INTERVAL));
// digitalWrite(greenLEDpin, HIGH);
// log milliseconds since starting
// uint32_t m = millis();
// logfile.print(m); // milliseconds since start
// logfile.print(", ");
#if ECHO_TO_SERIAL
// Serial.print(m); // milliseconds since start
// Serial.print(", ");
#endif
// fetch the time
now = RTC.now();
// log time
// logfile.print(now.unixtime()); // seconds since 1/1/1970
// logfile.print('"');
logfile.print(now.year(), DEC);
logfile.print("/");
logfile.print(now.month(), DEC);
logfile.print("/");
logfile.print(now.day(), DEC);
logfile.print(" ");
logfile.print(now.hour(), DEC);
logfile.print(":");
logfile.print(now.minute(), DEC);
logfile.print(":");
logfile.print(now.second(), DEC);
#if ECHO_TO_SERIAL
//Serial.print(now.unixtime()); // seconds since 1/1/1970
//Serial.print(", ");
//Serial.print('"');
Serial.print(now.year(), DEC);
Serial.print("/");
Serial.print(now.month(), DEC);
Serial.print("/");
Serial.print(now.day(), DEC);
Serial.print(" ");
Serial.print(now.hour(), DEC);
Serial.print(":");
Serial.print(now.minute(), DEC);
Serial.print(":");
Serial.print(now.second(), DEC);
// Get data from DHT-11
// digitalRead(dhtPin);
// delay(2000);
// int dhtReading = DHT.read11(dhtPin); // DHT11
// float t = DHT.temperature;
// float h = DHT.humidity;
digitalWrite(LED_BUILTIN,HIGH); // Flash the light!
int dhtData = dhtRead(); // Read DHT sensor
// Take leaf wetness reading
// delay(2000);
// int val = digitalRead(leafPin);
int val = readSensor();
// Determine status of leaf wetness sensor
if (val) {
Serial.print(", ");
Serial.print("Dry");
logfile.print("Dry");
} else {
Serial.print(", ");
Serial.print("Wet");
logfile.print("Wet");
// logfile.print(dhtReading);
logfile.print(DHT.temperature);
logfile.print(DHT.humidity);
logfile.println();
#if ECHO_TO_SERIAL
// Serial.print(dhtReading);
Serial.print(", ");
Serial.print(DHT.temperature);
Serial.print(", ");
Serial.print(DHT.humidity);
Serial.println();
// digitalWrite(greenLEDpin, LOW);
// Now we write data to disk! Don't sync too often - requires 2048 bytes of I/O to SD card
// which uses a bunch of power and takes time
if ((millis() - syncTime) < SYNC_INTERVAL) return;
syncTime = millis();
// // blink LED to show we are syncing data to the card & updating FAT!
logfile.flush();
// digitalWrite(redLEDpin, LOW);
// Function to wake-up leaf wetness sensor and return digital value (0 = wet, 1 = dry).
int readSensor() {
digitalWrite(leafPower, HIGH); // Turn the sensor ON
delay(10); // Allow power to settle
int val = digitalRead(leafPin); // Read the sensor output
digitalWrite(leafPower, LOW); // Turn the sensor OFF
return val; // Return the value
// Function to return DHT-11 Temperature & RH digital values
int dhtRead() {
digitalWrite(dhtPower, HIGH); // Turn the sensor ON
delay(2000); // Allow time for sensor to collect.
int dhtData = DHT.read11(dhtPin); // Read the sensor output
digitalWrite(dhtPower, LOW); // Turn the sensor OFF
return dhtData; // Return the values
return DHT.temperature;
return DHT.humidity;
