DHT.h library issue on Linux (Debian 10 Buster)
by weinhouse on Fri Jan 08, 2021 6:22 am
Sorry if this is the wrong place to post and please let me know where to post.
Was getting error:
/home/larryw/sketchbook/libraries/DHT_sensor_library141/DHT.cpp:31:3: error: ‘UINT32_MAX’ was not declared in this scope
UINT32_MAX /**< Used programmatically for timeout.
With some internet searching I added a line in DHT.cpp file:
#define UINT32_MAX 65535
Is this line correct? seems to work now, is there something else that could be the issue?
OS - Debian 10 Buster
Arduino IDE 2:1.o.5+dfsg2-4.1
weinhouse
Re: DHT.h library issue on Linux (Debian 10 Buster)
by adafruit_support_mike on Fri Jan 08, 2021 11:23 pm
Strictly speaking, it should be:
#define UINT32_MAX 0xffffffff
.. the maximum value you can store in a 32-bit unsigned integer.
Looking at the code though, the value is only used as a symbol indicating the microcontroller timed out waiting for a pulse to change. As long as the value you chose works, you should be okay.
by weinhouse on Mon Jan 11, 2021 5:42 pm
weinhouse
cron
