Adafruit 2.7” Tri-Color E-InK
by BrotherDan on Thu Mar 04, 2021 12:49 pm
Greetings,
I seem to be having trouble communicating with my newly arrived Adafruit 2.7” Tri-Color E-Ink display.
I am using this with an Arduino UNO and have copied the code for the EPD Graphicstest.
I initially successfully ran this sketch and had a response from the display, but after it stopped responding, I realized I had not uncommented the correct line to address the display.
I uncommented this line: Adafruit_IL91874 display(264, 176, EPD_DC, EPD_RESET, EPD_CS, SRAM_CS); and commented out the code line for the incorrect display.
I now have no response from the display when I run the sketch.
The display also does not respond when I reset using the reset button on the shield, nor does it respond when I change the EPD_RESET to -1 and reboot the system.
Has anyone else seen this behavior? If so, could you please give me guidance based on your experiences or expertise?
Thank you,
BrotherDan
BrotherDan
Re: Adafruit 2.7” Tri-Color E-InK
by adafruit_support_carter on Thu Mar 04, 2021 1:21 pm
Just to be sure, you are running this example sketch?
https://github.com/adafruit/Adafruit_EP ... cstest.ino
by BrotherDan on Thu Mar 04, 2021 1:36 pm
Yes...That is the sketch I am running.
BrotherDan
BrotherDan
by adafruit_support_carter on Thu Mar 04, 2021 1:43 pm
OK, let's check hardware also. Please post a photo of your setup showing how everything is connected.
by BrotherDan on Thu Mar 04, 2021 2:35 pm
Here’s a photo of my hardware setup. Fairly simple...Just the display shield riding on the UNO board.
Thanks...
BrotherDan
BrotherDan
by BrotherDan on Thu Mar 04, 2021 2:57 pm
Same response with a new ‘out of the box’ UNO board...
BrotherDan
BrotherDan
by adafruit_support_carter on Thu Mar 04, 2021 3:08 pm
What do you see in the Serial Monitor output when you run the program?
by BrotherDan on Thu Mar 04, 2021 3:28 pm
The serial monitor shows that that portion of the sketch is working as expected.
The serial monitor shows: “Hello! EPD Test Initialized”.
BrotherDan
BrotherDan
by adafruit_support_carter on Thu Mar 04, 2021 4:06 pm
Try setting both RESET and BUSY pins to -1:
#define EPD_CS     10
#define EPD_DC      9
#define SRAM_CS     8
#define EPD_RESET   -1 // can set to -1 and share with microcontroller Reset!
#define EPD_BUSY    -1 // can set to -1 to not use a pin (will wait a fixed delay)
by BrotherDan on Thu Mar 04, 2021 4:19 pm
EPD_RESEET and EPD_BUSY set to -1 and reloaded sketch...No change...
BrotherDan
BrotherDan
by BrotherDan on Fri Mar 05, 2021 3:45 pm
Greetings,
Any further recommendations?
I would like to continue to support Adafruit with my purchases for my Arduino (and now my Raspberry Pi) needs.
A significant portion of my decision-making process is my evaluation of how efficacious the support team is when I need their assistance.
Thank you,
BrotherDan
BrotherDan
by adafruit2 on Tue Mar 09, 2021 7:25 pm
we're debugging what happened. it used to work :D we recently did a lot of work on the EPD library and this seemed to have lost capabiltiy...
adafruit2
Site Admin
by BrotherDan on Tue Mar 09, 2021 8:42 pm
Thanks for getting back to me.
Let me know what you find and how I can resolve my technical difficulties.
BrotherDan
BrotherDan
by mamcgu on Tue Apr 20, 2021 8:49 pm
I have the 2.13" EPD display and am trying to get it to work with a UNO. No luck so far.
The pin assignments on the Arduino setup page are a bit different than the ones on the demo code--
SRAM_CS is assigned to 8 in the fritzing diagram and to 6 in the Arduino code ("#define SRAM_CS 6").
Mark
mamcgu
by adafruit_support_carter on Wed Apr 21, 2021 11:15 am
@mamcgu Please start a new thread for your issue.
@BrotherDan Did updating to the latest library fix this for you? (at least v.4.3.2)
