How Do I Play Tones on the Adafruit Magtag in Arduino?
by harbertc on Mon Apr 12, 2021 9:10 pm
The guide here, https://learn.adafruit.com/adafruit-mag ... ino-basics, says you can enable the speaker to "play tones or short audio clips" but there are no examples. I assumed "tone(A0, 440)" would work here, but the method is not declared. How do you get the Magtag to play tones in Arduino?
harbertc
Re: How Do I Play Tones on the Adafruit Magtag in Arduino?
by mikeysklar on Wed Apr 14, 2021 5:16 pm
Yeah tone() is not built into ESP32 Arduino Core.
You can use the ESP32Servo Library which has both analogWrite and tone builtin. It is available through the Arduino IDE library manager.
https://github.com/madhephaestus/ESP32Servo
Make sure you enable the speaker first.
// set speaker enable pin to output
  pinMode(SPEAKER_SHUTDOWN, OUTPUT);
  // and immediately disable it to save power
  digitalWrite(SPEAKER_SHUTDOWN, LOW);
mikeysklar
by adafruit2 on Thu Apr 15, 2021 1:33 pm
try using this funciton
void tone(uint8_t pin, float frequecy, float duration) {
  ledcSetup(1, frequecy * 80, 8);
  ledcAttachPin(pin, 1);
  ledcWrite(1, 128);
  delay(duration);
  ledcWrite(1, 0);
adafruit2
Site Admin
