Stepper Project not working
Re: Stepper Project not working
by adafruit_support_bill on Mon Apr 19, 2021 5:34 am
Please post some photos showing all of your soldering and connections.
by sadams260 on Mon Apr 19, 2021 7:13 am
No movement
sadams260
by adafruit_support_bill on Mon Apr 19, 2021 7:14 am
Does the display update?
Please post photos showing all your soldering and connections.
by sadams260 on Mon Apr 19, 2021 6:02 pm
It isnt soldered because it doesnt work at all. If I connect the 3.3 from the Uno to pin A3 the LCD does show the proper reading, If I connect to 5v the reading works and displays perfectly. It is the stepper which doesnt budge.
If I // all the LCD related lines of code the stepper works flawlessly
sadams260
by adafruit_support_bill on Mon Apr 19, 2021 7:54 pm
Correction: It doesn't work because it isn't soldered.
Solder your connections and post photos as requested.
by sadams260 on Mon Apr 19, 2021 8:03 pm
Ok will a screw shield suffice or is solder mandatory because the stepper board only has screw connections
The uno does not have any holes to solder to
sadams260
by adafruit_support_bill on Tue Apr 20, 2021 5:23 am
If you post photos as requested, we can see what boards you are using and whether any connections require solder.
by sadams260 on Tue Apr 20, 2021 7:59 pm
My photo is too big 1.3mb. Don't know how to make it smaller
sadams260
by adafruit_support_bill on Tue Apr 20, 2021 8:03 pm
Most photo apps allow you to export a resized image. If yours does not, there are lots of free online photo resizing sites on the web. About 800x600 images usually work best.
by sadams260 on Tue Apr 20, 2021 8:29 pm
wire
wire
sadams260
by adafruit_support_bill on Wed Apr 21, 2021 5:28 am
I don't see your display anywhere. And I don't recognize the motor control board you are using.
We also can't see what motor you are using, so it is not clear whether the UNO's regulator has sufficient power to drive it.
by sadams260 on Wed Apr 21, 2021 7:45 am
I dont have the display hooked up because I thought the draw was too much and that was the problem.
With that said if I // out the LCD lines of code the setup works perfectly. So it is my understanding that some how some way the code is the problem. The stepper doesnt budge.
As for the motor board I wanted to use Adafruits but dont understand the tutorials.
The sketch works with TB6600,the one shown and EasyDriver all driven just fine with the Uno.
sadams260
by adafruit_support_bill on Wed Apr 21, 2021 8:15 am
Trying to communicate with a device that isn't properly connected often results in the code getting stuck because the device doesn't respond. Disconnecting the device entirely does not improve things.
by sadams260 on Wed Apr 21, 2021 11:54 am
Ok understood, Ill hook everything up and repost a photo for perusal
sadams260
