Serial and I2C not working together
by pkatiyar on Tue Apr 20, 2021 11:03 am
I have very peculier problem. When I run this code SSD1306 fails to initialize. Outpu at serial console is:
20:26:33.194 -> MPU6050 OLED demo
20:26:33.532 -> SSD1306 allocation failed
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_MPU6050.h>
#include <Adafruit_SSD1306.h>
#include <Adafruit_Sensor.h>
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
#define OLED_RESET     4 // Reset pin # (or -1 if sharing Arduino reset pin)
#define SCREEN_ADDRESS 0x3D ///< See datasheet for Address; 0x3D for 128x64, 0x3C for 128x32
Adafruit_MPU6050 mpu;
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
int count =0;
  Serial.begin(9600);
  while (!Serial);
  Serial.println("MPU6050 OLED demo");
  if (!mpu.begin()) {
    Serial.println("Sensor init failed");
    while (1)
      yield();
  //Serial.println("Found a MPU-6050 sensor");
  // SSD1306_SWITCHCAPVCC = generate display voltage from 3.3V internally
  if (!display.begin(SSD1306_SWITCHCAPVCC, SCREEN_ADDRESS)) { // Address 0x3C for 128x32
    Serial.println(F("SSD1306 allocation failed"));
    for (;;)
      ; // Don't proceed, loop forever
  display.display();
  delay(500); // Pause for 2 seconds
  display.setTextSize(1);
  display.setTextColor(WHITE);
  display.setRotation(0);
  sensors_event_t a, g, temp;
  mpu.getEvent(&a, &g, &temp);
  display.clearDisplay();
  display.setCursor(0, 0);
  display.println("Accelerometer - m/s^2");
  display.print(a.acceleration.x, 1);
  display.print(", ");
  display.print(a.acceleration.y, 1);
  display.print(a.acceleration.z, 1);
  display.println("");
  display.println("Gyroscope - rps");
  display.print(g.gyro.x, 1);
  display.print(g.gyro.y, 1);
  display.print(g.gyro.z, 1);
  display.display();
  delay(100);
But when I run this code, without displaying gyro everything runs fine. Adafruit logo is displayed and then followed by regular accelerometer data.
#include <Wire.h>
int count =0;
  Serial.begin(9600);
  while (!Serial);
  if (!mpu.begin()) {
    while (1)
      yield();
    for (;;)
  display.display();
  display.display();
  delay(100);
Now, while debugging when I disable Serial logs and comment all Serial.print then the above code runs properly, logo is displayed, accelerometer and gyro both the data are displayed on OLED properly.
Compiler Log for non-working code is:
Sketch uses 21980 bytes (71%) of program storage space. Maximum is 30720 bytes.
Global variables use 761 bytes (37%) of dynamic memory, leaving 1287 bytes for local variables. Maximum is 2048 bytes.
The setup I am using as Arduino Nano, MPU6050 connected over I2C (address 0x68), SSD1306 based 0.96" 128x64 display over I2C (address 0x3D). I am using A4 and A5 pin of Arduino Nano as I2C. Both device are connected over same bus. I am using breadboard for testing.
PS: Both the code compiles without error or warning
pkatiyar
Re: Serial and I2C not working together
by adafruit_support_carter on Tue Apr 20, 2021 12:05 pm
The two codes look the same?
by pkatiyar on Tue Apr 20, 2021 7:46 pm
Made copy paster mistake:
In working code all the serial prints are commented while in non-working code they are not. I have corrected it here
pkatiyar wrote:Hi,
#include <Wire.h>
int count =0;
  //Serial.begin(9600);
  //while (!Serial);
  //Serial.println("MPU6050 OLED demo");
  if (!mpu.begin()) {
    //Serial.println("Sensor init failed");
    while (1)
      yield();
    for (;;)
  display.display();
  display.display();
  delay(100);
#include <Wire.h>
int count =0;
  Serial.begin(9600);
  while (!Serial);
  if (!mpu.begin()) {
    while (1)
      yield();
    for (;;)
  display.display();
  display.display();
  delay(100);
pkatiyar
by pkatiyar on Thu Apr 22, 2021 12:24 pm
It was low RAM problem.
SSD1306 takes 1K, with MPU6050 the and serial print which I have included the remaining RAM is 5 bytes only, hence the initialization issue.
I followed simple guideline to reduce RAM footprint
Read this thread https://stackoverflow.com/questions/864 ... in-arduino
Code to print available SRAM.
Serial.print(availableMemory());
// free RAM check for debugging. SRAM for ATmega328p = 2048Kb.
int availableMemory() {
// Use 1024 with ATmega168
int size = 2048;
byte *buf;
while ((buf = (byte *) malloc(--size)) == NULL);
free(buf);
return size;
pkatiyar
by adafruit_support_carter on Thu Apr 22, 2021 1:32 pm
Cool. Glad you figured it out. That's an annoying issue that can be tricky to troubleshoot sometimes.
