BNO055 with Arduino 2560 pro mini
by Finist on Tue Apr 20, 2021 1:45 pm
Good day!
In our project we use BNO055 and Arduino mega pro 2560, 4 motors with drivers, bluetooth module and few I2C sensors. Everything works great, but there is one problem. After a few seconds, or minutes of work, BNO055 freezes: sensor readings sent via bluetooth are 0. If we using old library, then arduino freezes. After restarting, everything works just as well for a few seconds or minutes.
x = bno.getHeading();
vr = (((x - prd) + 540) % 360) - 180;
Serial1.println(vr);
delay(10);
If we only read the values from the sensor and send them via bluetooth (while not using them anywhere in our calculations), everything also works fine.
vr = (((0 - prd) + 540) % 360) - 180;
Serial1.println(x);
delay(10);
Finist
Re: BNO055 with Arduino 2560 pro mini
by blnkjns on Wed Apr 21, 2021 12:54 am
Is there anywhere a variable involved that has "room to grow" to the point of memory overflow? For example a data buffer somewhere? Check any pointers in your code, and make sure array counters do not get out of bounds.
blnkjns
