APDS9960 and SparkFun Qwiic Mux not working
by GradeSchool on Wed May 05, 2021 8:34 pm
I'm using a SparkFun Qwiic Mux https://www.adafruit.com/product/4704 with some APDS9960 sensors https://www.adafruit.com/product/3595. I'm porting a project from CircuitPython to Arduino (referenced here: https://forums.adafruit.com/viewtopic.php?f=60&t=178401). I'm running the following code on and Arduino Uno.
#include <Wire.h>
#include <SparkFun_I2C_Mux_Arduino_Library.h>
#include "Adafruit_APDS9960.h"
QWIICMUX myMux_70;
Adafruit_APDS9960 apds_00;
void setup()
  Serial.begin(115200);
  Wire.begin();
  myMux_70.begin(0x70);
  apds_00.begin();
  apds_00.enableProximity(true);
  apds_00.setProximityInterruptThreshold(0, 255);
void loop()
  myMux_70.setPort(0);
  Serial.print('A');
  Serial.println(apds_00.readProximity());
  delay(100);
I've verified that my sensor responds (when not connected via Mux) and that the Mux and sensor are detected on the I2C bus- using the BasicControl example in the SparkFun_I2C_Mux_Arduino_Library.
My goal is to get one sensor working on one Mux and to build up to 32 sensors across 4 Mux. The above code results in no reading from the APDS9600. Can anyone see an obvious (or not so obvious) issue with this setup? Thanks in advance.
GradeSchool
Re: APDS9960 and SparkFun Qwiic Mux not working
by adafruit_support_carter on Thu May 06, 2021 4:14 pm
Try adding a call to setPort() in setup() before initializing the APDS.
Also, since you currently are not using any other outputs, you don't need the call to setPort() in the loop.
