Symmetrical LED movement?
by mechno on Fri May 07, 2021 4:55 pm
Hello all! I'm wondering if anyone has some suggestion for me to adapt the ampli-tie code to make 1/2 of a neopixel strip mirror the other half.
for instance on a 16 neopixel stip, 1+16 do the same thing, 2+15, and so forth.
I've done this before by just splitting the dataline off before the first LED, but I'd like to figure out how to do this in software.
If anyone has advice or even if you take a glance, thanks!
Here's the code I'm trying to finesse:
> cat ampli-tie.ino
LED VU meter for Arduino and Adafruit NeoPixel LEDs.
 Hardware requirements:
 - Most Arduino or Arduino-compatible boards (ATmega 328P or better).
 - Adafruit Electret Microphone Amplifier (ID: 1063)
 - Adafruit Flora RGB Smart Pixels (ID: 1260)
 OR
 - Adafruit NeoPixel Digital LED strip (ID: 1138)
 - Optional: battery for portable use (else power through USB or adapter)
 Software requirements:
 - Adafruit NeoPixel library
 Connections:
 - 3.3V to mic amp +
 - GND to mic amp -
 - Analog pin to microphone output (configurable below)
 - Digital pin to LED data input (configurable below)
 See notes in setup() regarding 5V vs. 3.3V boards - there may be an
 extra connection to make and one line of code to enable or disable.
 Written by Adafruit Industries.  Distributed under the BSD license.
 This paragraph must be included in any redistribution.
 fscale function:
 Floating Point Autoscale Function V0.1
 Written by Paul Badger 2007
 Modified from code by Greg Shakar
#include <math.h>
#define N_PIXELS  16  // Number of pixels in strand
#define MIC_PIN   1  // Microphone is attached to this analog pin
#define LED_PIN   4  // NeoPixel LED strand is connected to this pin
#define SAMPLE_WINDOW   10  // Sample window for average level
#define PEAK_HANG 24 //Time of pause before peak dot falls
#define PEAK_FALL 4 //Rate of falling peak dot
#define INPUT_FLOOR 10 //Lower range of analogRead input
#define INPUT_CEILING 1023 //Max range of analogRead input, the lower the value the more sensitive (1023 = max)
byte peak = 16;      // Peak level of column; used for falling dots
unsigned int sample;
byte dotCount = 0;  //Frame counter for peak dot
byte dotHangCount = 60; //Frame counter for holding peak dot
Adafruit_NeoPixel strip = Adafruit_NeoPixel(N_PIXELS, LED_PIN, NEO_GRB + NEO_KHZ800);
void setup()
  // This is only needed on 5V Arduinos (Uno, Leonardo, etc.).
  // Connect 3.3V to mic AND TO AREF ON ARDUINO and enable this
  // line.  Audio samples are 'cleaner' at 3.3V.
  // COMMENT OUT THIS LINE FOR 3.3V ARDUINOS (FLORA, ETC.):
  //  analogReference(EXTERNAL);
  // Serial.begin(9600);
  strip.begin();
  strip.show(); // Initialize all pixels to 'off'
void loop()
  unsigned long startMillis= millis();  // Start of sample window
  float peakToPeak = 0;   // peak-to-peak level
  unsigned int signalMax = 0;
  unsigned int signalMin = 1023;
  unsigned int c, y;
  // collect data for length of sample window (in mS)
  while (millis() - startMillis < SAMPLE_WINDOW)
    sample = analogRead(MIC_PIN);
    if (sample < 1024)  // toss out spurious readings
      if (sample > signalMax)
        signalMax = sample;  // save just the max levels
      else if (sample < signalMin)
        signalMin = sample;  // save just the min levels
  peakToPeak = signalMax - signalMin;  // max - min = peak-peak amplitude
  // Serial.println(peakToPeak);
  //Fill the strip with rainbow gradient
  for (int i=0;i<=strip.numPixels()-1;i++){
    strip.setPixelColor(i,Wheel(map(i,0,strip.numPixels()-1,30,150)));
  //Scale the input logarithmically instead of linearly
  c = fscale(INPUT_FLOOR, INPUT_CEILING, strip.numPixels(), 0, peakToPeak, 2);
  if(c < peak) {
    peak = c;        // Keep dot on top
    dotHangCount = 1;    // make the dot hang before falling
  if (c <= strip.numPixels()) { // Fill partial column with off pixels
    drawLine(strip.numPixels(), strip.numPixels()-c, strip.Color(0, 0, 0));
  // Set the peak dot to match the rainbow gradient
  y = strip.numPixels() - peak;
  strip.setPixelColor(y-1,Wheel(map(y,0,strip.numPixels()-1,30,150)));
  strip.show();
  // Frame based peak dot animation
  if(dotHangCount > PEAK_HANG) { //Peak pause length
    if(++dotCount >= PEAK_FALL) { //Fall rate
      peak++;
      dotCount = 0;
  else {
    dotHangCount++;
//Used to draw a line between two points of a given color
void drawLine(uint8_t from, uint8_t to, uint32_t c) {
  uint8_t fromTemp;
  if (from > to) {
    fromTemp = from;
    from = to;
    to = fromTemp;
  for(int i=from; i<=to; i++){
    strip.setPixelColor(i, c);
float fscale( float originalMin, float originalMax, float newBegin, float
newEnd, float inputValue, float curve){
  float OriginalRange = 0;
  float NewRange = 0;
  float zeroRefCurVal = 0;
  float normalizedCurVal = 0;
  float rangedValue = 0;
  boolean invFlag = 0;
  // condition curve parameter
  // limit range
  if (curve > 10) curve = 10;
  if (curve < -10) curve = -10;
  curve = (curve * -.1) ; // - invert and scale - this seems more intuitive - postive numbers give more weight to high end on output
  curve = pow(10, curve); // convert linear scale into lograthimic exponent for other pow function
   Serial.println(curve * 100, DEC);   // multply by 100 to preserve resolution
   Serial.println();
  // Check for out of range inputValues
  if (inputValue < originalMin) {
    inputValue = originalMin;
  if (inputValue > originalMax) {
    inputValue = originalMax;
  // Zero Refference the values
  OriginalRange = originalMax - originalMin;
  if (newEnd > newBegin){
    NewRange = newEnd - newBegin;
  else
    NewRange = newBegin - newEnd;
    invFlag = 1;
  zeroRefCurVal = inputValue - originalMin;
  normalizedCurVal  =  zeroRefCurVal / OriginalRange;   // normalize to 0 - 1 float
  // Check for originalMin > originalMax  - the math for all other cases i.e. negative numbers seems to work out fine
  if (originalMin > originalMax ) {
    return 0;
  if (invFlag == 0){
    rangedValue =  (pow(normalizedCurVal, curve) * NewRange) + newBegin;
  else     // invert the ranges
    rangedValue =  newBegin - (pow(normalizedCurVal, curve) * NewRange);
  return rangedValue;
// Input a value 0 to 255 to get a color value.
// The colours are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos) {
  if(WheelPos < 85) {
    return strip.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
  else if(WheelPos < 170) {
    WheelPos -= 85;
    return strip.Color(255 - WheelPos * 3, 0, WheelPos * 3);
  else {
    WheelPos -= 170;
    return strip.Color(0, WheelPos * 3, 255 - WheelPos * 3);
mechno
Re: Symmetrical LED movement?
by mikeysklar on Sun May 09, 2021 3:56 pm
I don't have an exact code example to mirror NeoPixel strips, but we do have one guide that uses NeoPixels called the "Larson Scanner Shades" that bounces a progressive line of LEDs back and forth that has some overlapping code you can adapt.
https://learn.adafruit.com/larson-scann ... duino-code
#define N_LEDS 22
#define PIN     4
Adafruit_NeoPixel strip = Adafruit_NeoPixel(N_LEDS, PIN, NEO_GRB + NEO_KHZ800);
  strip.begin();
int pos = 0, dir = 1; // Position, direction of "eye"
  int j;
  // Draw 5 pixels centered on pos.  setPixelColor() will clip any
  // pixels off the ends of the strip, we don't need to watch for that.
  strip.setPixelColor(pos - 2, 0x100000); // Dark red
  strip.setPixelColor(pos - 1, 0x800000); // Medium red
  strip.setPixelColor(pos    , 0xFF3000); // Center pixel is brightest
  strip.setPixelColor(pos + 1, 0x800000); // Medium red
  strip.setPixelColor(pos + 2, 0x100000); // Dark red
  strip.show();
  delay(30);
  // Rather than being sneaky and erasing just the tail pixel,
  // it's easier to erase it all and draw a new one next time.
  for(j=-2; j<= 2; j++) strip.setPixelColor(pos+j, 0);
  // Bounce off ends of strip
  pos += dir;
  if(pos < 0) {
    pos = 1;
    dir = -dir;
  } else if(pos >= strip.numPixels()) {
    pos = strip.numPixels() - 2;
    dir = -dir;
mikeysklar
by mechno on Mon May 10, 2021 8:42 am
Thank you! This is a great start for me!
mechno
by mikeysklar on Mon May 10, 2021 5:33 pm
Oh good. Since it was not an exact match to what you were asking for I was hesitant to link it in. Go ahead and post your solution if you work it out.
mikeysklar
