Servo feedback signal noise spikes
by Bruce_Abbott on Thu May 27, 2021 12:04 pm
My Adafruit feedback servos produce large noise spikes at quasi-regular intervals while servo is driven between min and max angles at the rate of 1 degree per loop iteration, as shown in the accompanying image taken from the Arduino Serial Plotter. I would like to understand why this is happening, and eliminate it if possible. Such large spikes in position feedback make the feedback signal unreliable. The pattern shown is not unique to a particular servo as it replicates with others. The sketch driving the servo includes a small delay between setting the reference and reading the analog signal to reduce the chance that servo-motor actuation would generate the noise-spike in the analog channel. Any ideas why these spikes are being generated?
Reference and feedback signal during triangle ramp of servo reference
Bruce_Abbott
Re: Servo feedback signal noise spikes
by adafruit_support_bill on Thu May 27, 2021 12:16 pm
Please post the code that you are using.
by Bruce_Abbott on Thu May 27, 2021 10:38 pm
Here is the script used to generate the output shown in the first post:
// Code based on Bill Earl's examples in his article "Analog Feedback Servos."
#include <Servo.h>
Servo myservo;
// Control and feedback pins
int servoPin = 9;
int feedbackPin = A0;
// Calibration values
int minDegrees;
int maxDegrees;
int minFeedback;
int maxFeedback;
int tolerance = 2; // max feedback measurement error
int servoAngle;
int servoRef;
int dt = 10;
int maxAngle = 160;
int minAngle = 0;
  This function establishes the feedback values for 2 positions of the servo.
  With this information, we can interpolate feedback values for intermediate positions
void calibrate(Servo servo, int analogPin, int minPos, int maxPos)
  // Move to the minimum position and record the feedback value
  servo.write(minPos);
  minDegrees = minPos;
  delay(2000); // make sure it has time to get there and settle
  minFeedback = analogRead(analogPin);
  // Move to the maximum position and record the feedback value
  servo.write(maxPos);
  maxDegrees = maxPos;
  maxFeedback = analogRead(analogPin);
void setup()
  Serial.begin(9600);
  myservo.attach(servoPin);
  calibrate(myservo, feedbackPin, 20, 160);  // calibrate for the 20-160 degree range
void Seek(Servo servo, int analogPin, int pos)
  // Start the move...
  servo.write(pos);
  // Calculate the target feedback value for the final position
  int target = map(pos, minDegrees, maxDegrees, minFeedback, maxFeedback);
  // Wait until it reaches the target
  while(abs(analogRead(analogPin) - target) > tolerance){} // wait...
int getPos(int analogPin)
  // Return the servo's actual position based on feedback signal
  return map(analogRead(analogPin), minFeedback, maxFeedback, minDegrees, maxDegrees);
void loop()
  // ramp up
  for (int i = minAngle; i <= maxAngle; i++) {
     servoRef = i;
    myservo.write(servoRef);
    //Seek(myservo, feedbackPin, servoRef);
    delay(dt);
    servoAngle = getPos(feedbackPin);
    Serial.print(servoRef);
    Serial.print("\t");
    Serial.println(servoAngle);
  // ramp down
  for (int i = maxAngle-1; i >= minAngle+1; i--) {
    servoRef = i;
    delay(dt);
    Serial.print("\t");
Feedback_servo.ino
(2.42 KiB) Downloaded 2 times
Bruce_Abbott
by adafruit_support_bill on Fri May 28, 2021 6:44 am
The spikes are most likely due to interference from the servo motor. I'd try increasing the settling time between moves to see if that makes an appreciable difference. The internal PID for the servo is tuned at the factory for some 'typical' load. That means it will be underdamped when unloaded and have a tendency to overshoot and oscillate. So it might take a little longer before the motor activity settles down.
by Bruce_Abbott on Fri May 28, 2021 11:12 am
Indeed there is much less spiking when the delay between servo actuation and analog feedback read is increased from 10 ms to 100 ms:
100 ms delay to allow servo to settle, no load on servo
However, when I added a load opposing the direction of servo rotation, I get an even worse problem:
100 ms delay between servo actuation and analog feedback read, with added load resisting direction of servo rotation
Bruce_Abbott
by adafruit_support_bill on Fri May 28, 2021 4:03 pm
Not too surprising. A typical RC servo control loop is tuned for some arbitrary 'average' load. So it will be overdamped for some and underdamped for others. In either case, when the tuning is less than ideal it takes longer to converge on the target position.
The feedback on these servos is simply a secondary tap into the servo's internal feedback pot. In an ideal world, that should give you position feedback identical to what the servo sees. But in the real world, wires and connections have resistance, so there will be a voltage drop proportional to the current flow. That means when the motor is moving, both the power and ground potential at the servo will be different than at your processor. To minimize that, be sure to keep your wires short and your connections solid.
