LPD8806 RBG LED strip issue - newbie
by sutliff2000 on Thu May 27, 2021 4:26 pm
Hi
I am just starting to work with Arduino. I have walked through the basic tutorials. I need to get a LED strip to blink or marquee for a project. But when I upload the code it only shows one color continuously.
I am using the wiring displayed here: https://learn.adafruit.com/digital-led-strip/wiring I have double checked all the wiring to it matches the schematic.
I am not using the LPD8806 strip though. I am using a generic RGB LED strip from another company. Does this make a difference?
I am using the code straight from the library - no alterations. https://learn.adafruit.com/digital-led-strip/code Is there a different code I should be using for a generic LED strip?
I clear the Arduino Uno by pressing the button. The LED lights turn Green. I compile the code. I upload the code. The lights turn a Blue-ish color. No blinking, no scrolling.
I have tried switching the clock wire and the data wire just in case I got backwards.
sutliff2000
Re: LPD8806 RBG LED strip issue - newbie
by dastels on Thu May 27, 2021 4:34 pm
Your strip could very well make a huge difference. Exactly what is it? Do you have a link to it?
dastels
by sutliff2000 on Thu May 27, 2021 4:38 pm
13.2 Feet Battery Powered Led Strip Lights,DIY Color Changing Led Lights Battery Operated
https://www.amazon.com/gp/product/B089YQPXBG/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1
I used most of it for a project so I thought I could use the last 13 LEDs for one more part. But the switch that came with it was used on the first part so I wanted to program my own.
sutliff2000
by dastels on Thu May 27, 2021 5:08 pm
It all depends on what the LED modules are. What are the connections on the strip? Can the different LEDs be set to different colors or is all of it a single color at a time?
Unfortunately that product listing doesn't have much useful information.
dastels
by sutliff2000 on Thu May 27, 2021 5:19 pm
Thanks, Dave for your help.
I've attached an image of the strip connection. I don't know how to change the colors. Is there a basic code I could play with first?
LED Strip.jpg (75.47 KiB) Viewed 300 times
sutliff2000
by dastels on Thu May 27, 2021 8:19 pm
The guide you used for wiring (LPD8806 Digital RGB LED Strip) is not for the strip you have. You have an analog RGB strip. That means a couple things: you directly control the red, green, and blue channels via PWMing them through a power transister, and the whole strip can be a single color at a time (i.e. different LEDs can't be different colors at the same time).
You want to read through this guide: https://learn.adafruit.com/rgb-led-strips. Code examples are provided. Pay special attention to https://learn.adafruit.com/rgb-led-strips/usage.
dastels
by sutliff2000 on Thu May 27, 2021 8:39 pm
Thank you so much!
Have a great night.
sutliff2000
by dastels on Thu May 27, 2021 8:52 pm
Note that the guide I linked to is for a 12v strip. You have a 5v strip, but the only difference is the power voltage.I'm not sure how your strip is wired so it's had to say what kind of current you'll need.
dastels
by sutliff2000 on Fri May 28, 2021 10:40 am
Can I ask another question here or do I need to start a new thread?
I'm just wondering if I can substitute a Nano for the Uno. The Uno seems to be more than what I need and hard to conceal.
sutliff2000
by dastels on Fri May 28, 2021 11:04 am
Sure, the Nano is pretty much the same as the UNO in a smaller package.
dastels
by sutliff2000 on Fri May 28, 2021 11:08 am
sutliff2000
