Access the NFC Tag on NRF52840
by Ben_L on Fri May 28, 2021 11:47 am
Hey Everyone!
I have recently got a NRF52840 and i want to make use of its inbuilt NFC-Tag using the Arduino IDE.
I am posting here, because after a lot of research, i still could not find an example project or code, that adresses this topic.
Also, while there is an Example on how to change the NFC Pins to GPIO Pins on the Board, there is no real Example on how to use the NFC tag itself.
Am i correct to assume, that it should be possible to set a certain Text/Dataset via the Code and then read it from the board using my phone for example?
If that is the case: Is there some example code or documentation available?
Thanks in advance!
Ben_L
Re: Access the NFC Tag on NRF52840
by adafruit_support_mike on Fri May 28, 2021 10:50 pm
I'm afraid we don't have any information about using the nRF52840 in NFC mode. Maybe someone from the community will have more information.
