adafruit-nrfutil not found by Arduino IDE (v 1.8.13)
by lunch_box on Mon May 31, 2021 7:08 pm
I'm trying to compile and flash one of the example programs for the ItsyBitsy nRF52840 Express, but I keep getting the following error:
Arduino: 1.8.13 (Linux), Board: "Adafruit ItsyBitsy nRF52840 Express, 0.2.11 SoftDevice s140 6.1.1, Level 0 (Release)"
Library Adafruit_nRFCrypto has been declared precompiled:
Using precompiled library in /home/lunch_box/snap/arduino/56/.arduino15/packages/adafruit/hardware/nrf52/0.22.1/libraries/Adafruit_nRFCrypto/src/cortex-m4/fpv4-sp-d16-hard
exec: "adafruit-nrfutil": executable file not found in $PATH
Error compiling for board Adafruit ItsyBitsy nRF52840 Express.
I followed the installation instructions here
https://learn.adafruit.com/adafruit-its ... port-setup
and verified that the tool is installed and in the PATH environment variable.
lunch_box@neptune:~$ adafruit-nrfutil version
adafruit-nrfutil version 0.5.3.post16
lunch_box@neptune:~$ which adafruit-nrfutil
/home/lunch_box/.local/bin/adafruit-nrfutil
This is pretty frustrating. Any ideas?
lunch_box
Re: adafruit-nrfutil not found by Arduino IDE (v 1.8.13)
by adafruit_support_mike on Mon May 31, 2021 11:03 pm
That probably means something is messed up in the board support packages.
Try deleting your Arduino15 folder and reinstalling the board support packages from scratch.
by lunch_box on Mon Jun 21, 2021 6:06 pm
adafruit_support_mike wrote:That probably means something is messed up in the board support packages.
Did that, and tried installing fresh from the github repo. Exact same result, and even duplicated it on a totally different computer. Any suggestions?
lunch_box
by lunch_box on Wed Jun 23, 2021 9:20 pm
No ideas? Can't use this product at all until I get this figured out.
lunch_box
by adafruit_support_mike on Sun Jun 27, 2021 12:18 am
What do you get when you enter:
echo $PATH
by lunch_box on Wed Jun 30, 2021 8:13 pm
lunch_box@neptune:~$ echo $PATH
/home/lunch_box/gems/bin:/home/lunch_box/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
lunch_box
by adafruit_support_mike on Thu Jul 01, 2021 3:52 pm
Hrm.. it's obviously there from the command line. Assuming you modified $PATH in .profile (or its equivalent), does the line that sets $PATH use the 'export' keyword?
Unfortunately I don't know how to make the Arduino IDE show the $PATH variable it sees. You might want to check with the folks in the Arduino forums about that,
Try dropping a symlink to `adafruit-nrfutil` in one of the directories that's always in $PATH, like /usr/local/bin . See if that has any effect on the IDE's ability to find it.
