adafruit-nrfutil not found by Arduino IDE (v 1.8.13)
lunch_box
Post by lunch_box »
I'm trying to compile and flash one of the example programs for the ItsyBitsy nRF52840 Express, but I keep getting the following error:
Arduino: 1.8.13 (Linux), Board: "Adafruit ItsyBitsy nRF52840 Express, 0.2.11 SoftDevice s140 6.1.1, Level 0 (Release)"
Library Adafruit_BANNED has been declared precompiled:
Using precompiled library in /home/lunch_box/snap/arduino/56/.arduino15/packages/adafruit/hardware/nrf52/0.22.1/libraries/Adafruit_BANNED/src/cortex-m4/fpv4-sp-d16-hard
exec: "adafruit-nrfutil": executable file not found in $PATH
Error compiling for board Adafruit ItsyBitsy nRF52840 Express.
I followed the installation instructions here
https://learn.adafruit.com/adafruit-its ... port-setup
and verified that the tool is installed and in the PATH environment variable.
lunch_box@neptune:~$ adafruit-nrfutil version
adafruit-nrfutil version 0.5.3.post16
lunch_box@neptune:~$ which adafruit-nrfutil
/home/lunch_box/.local/bin/adafruit-nrfutil
This is pretty frustrating. Any ideas?
adafruit_support_mike
Re: adafruit-nrfutil not found by Arduino IDE (v 1.8.13)
That probably means something is messed up in the board support packages.
Try deleting your Arduino15 folder and reinstalling the board support packages from scratch.
lunch_box
Post by lunch_box »
adafruit_support_mike wrote:That probably means something is messed up in the board support packages.
Did that, and tried installing fresh from the github repo. Exact same result, and even duplicated it on a totally different computer. Any suggestions?
lunch_box
Post by lunch_box »
No ideas? Can't use this product at all until I get this figured out.
What do you get when you enter:
echo $PATH
lunch_box
Post by lunch_box »
lunch_box@neptune:~$ echo $PATH
/home/lunch_box/gems/bin:/home/lunch_box/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
Hrm.. it's obviously there from the command line. Assuming you modified $PATH in .profile (or its equivalent), does the line that sets $PATH use the 'export' keyword?
Unfortunately I don't know how to make the Arduino IDE show the $PATH variable it sees. You might want to check with the folks in the Arduino forums about that,
Try dropping a symlink to `adafruit-nrfutil` in one of the directories that's always in $PATH, like /usr/local/bin . See if that has any effect on the IDE's ability to find it.
Return to “Arduino”
