Photoelectric Sensor Switch Problem
by Joey713 on Sat Jun 19, 2021 2:17 am
Hi, all
I am doing a project that use arduino uno to switch on and off a photoelectric sensor (according to Infrared Photoelectric Switch Source: https://www.apogeeweb.net/electron/basic-principles-and-development-of-photoelectric-sensor.html). How do i test the current of the output signal black wire as i worry that the arduino can only take in 5V and 40mA. I have connected the brown to 18V power supply, blue to collector of transistor and 5V supply to the base transistor.
Parts Used:
NPN photoelectric sensor
supply voltage 10-30V
output current <100mA
power consumption <20mA
NPN Transistor 2n3904
Joey713
Re: Photoelectric Sensor Switch Problem
by adafruit_support_bill on Sat Jun 19, 2021 6:59 am
Photoelecric sensors are switched by light. Are you using the UNO to drive a light to actuate the sensor?
The document you linked is a general information document for many sensors. It does not have pinouts details for any specific one. Please post a link to the sensor you are using - as well as a diagram of your complete circuit.
by Joey713 on Wed Jun 23, 2021 3:20 am
Photoelecric sensors are switched by light. If the sensor output is "NPN open collector", can I use INPUT_PULLUP on the Arduino input pin?
Joey713
by adafruit_support_bill on Wed Jun 23, 2021 6:05 am
Yes.
