Hello
I'm new to all this and my head is spinning.
I want to set up the ring light which I bought from you with an Arduino and also a light controller that @johnedgarpark uses in this "
in this video: https://www.youtube.com/watch?v=I7kWraqKYCk
I bought the ring light, the Controllable Four Outlet Power Relay Module version 2, and I have the Arduino to set what @johnedgarpark
is doing in this video. I have the reflective material already too.
Can I buy what he has already created? The ring with the controller to increase and decrease the light intensity? Or can I buy that controller?
I hope this all make sense.
Thank you
Adrduino + Ring Light @johnedgarpark
- Lovekaisei17
- WhatsApp Image 2021-07-14 at 1.06.09 PM.jpeg (178.02 KiB) Viewed 167 times
- 815k0WXLkQL.png (265.62 KiB) Viewed 167 times
- 2935-13.jpeg (22.69 KiB) Viewed 167 times
- mikeysklar
Re: Adrduino + Ring Light @johnedgarpark
You will want to follow the setup John Park has in this guide:
https://learn.adafruit.com/retroreflect ... controller
The QtPy controller and rotary encoder are the main bits, but pickup the smaller stuff also mentioned if you do not already have it.
- Lovekaisei17
Thank you!
Man! Can someone build that and charge me?
My head is spinning... I'm not from this world of engineering!
- mikeysklar
These projects are intimidating at first. Maybe you could order the components and go to a local hackerspace or find a more experienced friend to help go through the step-by-step with you?
- Lovekaisei17
Thank you Mikeysklar!
Yes, I'm looking for a store in NY.
