2.2 TFT Solid White
- mubachs
2.2 TFT Solid White
Just got a 2.2 TFT and got it wired up to test. Everything worked great then I re uploaded the exact same sketch and suddenly the display is solid white and can not get anything to work. Any ideas I could test or can I get a replacement?
- Franklin97355
Re: 2.2 TFT Solid White
What sketch did you load and what board are you using to control it? Can you post pictures of the display, its connections, and the soldering?
- mubachs
Following the guide here: https://learn.adafruit.com/2-2-tft-disp ... ino-wiring
I am using a genuine Arduino Uno and I am using the Adafruit ILI9341 graphic test example sketch with no modifications. As I stated I just got the display yesterday and it worked at first, then with absolutely no change it went white and wont respond now.
- Franklin97355
All the soldering looks good except the ground. Can you reflow it to see if that helps?
- mubachs
I just used a bit to much solder. Re soldered and still white.
- Franklin97355
OK let's replace it and see if this fixes it. Contact [email protected] with a link to this thread and they will get you a new one.
