Hi, I am looking for an Arduino compatible (i.e. that is programmed in the Arduino IDE ) small board that have 2 hardware UARTs.
I know that the MEGA2560 has more UARTs but its form factor is too big for my needs.
Do you have any suggestions?
At the moment I prefer Hardware UARTs, I need the board to be in the middle between two modules and relay and handle the UART communication between them.
Amnon
Arduino compatible small board with 2 hardware UARTs.
- amnond
Re: Arduino compatible small board with 2 hardware UARTs.
You could use one of the M0-based boards like this Feather: https://www.adafruit.com/product/2772
You can configure multiple hardware UARTs via SERCOM: https://learn.adafruit.com/using-atsamd ... rial-ports
- amnond
Hi, Thank you for the prompt answer! I will surely look at those options.
Thanks, Amnon
Thanks, Amnon
