Adafruit Zero I2S library not working with RTCZero library
jmacarthur
Post by jmacarthur »
Anyone else come across this? If you start with the "basic" example from the Adafruit Zero I2S library, and add RTC functionality, it breaks the I2S. You don't have to do anything more than rtc.begin, so I'm not sleeping the processor or anything. I'm using a stock MKRZero with Adafruit MAX98357A I2S amplifier. Code below. Comment out rtc.begin() and it works fine.
#include <Arduino.h>
#include <Adafruit_ZeroI2S.h>
#include <math.h>
#include <RTCZero.h>
// Copied from Adafruit I2S basic example, added RTC. rtc.begin() breaks I2S
/* max volume for 32 bit data */
#define VOLUME ( (1UL << 31) - 1)
#define MUTEPIN 5
/* create a buffer for both the left and right channel data */
#define BUFSIZE 128
int left[BUFSIZE];
int right[BUFSIZE];
/* Create an rtc object */
RTCZero rtc;
// Use default pins in board variant
Adafruit_ZeroI2S i2s = Adafruit_ZeroI2S();
void setup()
pinMode(MUTEPIN,OUTPUT); // MUTE
digitalWrite(MUTEPIN,HIGH); //start out unmuted
rtc.begin(); //fails until you comment it out
// while (!Serial) delay(10);
// Serial.println("I2S demo");
for(int i=0; i<BUFSIZE; i++){
/* create a sine wave on the left channel */
left = sin( (2*PI / (BUFSIZE) ) * i) * VOLUME;
/* create a cosine wave on the right channel */
right = cos( (2*PI / (BUFSIZE) ) * i) * VOLUME;
/* begin I2S on the default pins. 24 bit depth at
* 44100 samples per second
i2s.begin(I2S_32_BIT, 44100);
i2s.enableTx();
void loop()
/* write the output buffers
* note that i2s.write() will block until both channels are written.
i2s.write(left, right);
mikeysklar
Re: Adafruit Zero I2S library not working with RTCZero libra
Post by mikeysklar »
Yes, I believe this is an open issue.
https://github.com/arduino/ArduinoCore-samd/issues/451
"Incompatibility between MKRZERO RTC & I2S libraries #451"
robertcarell
Post by robertcarell »
yup, it happens a lot, when you are working on Arduino and using third party libraries, they don't get compatible with each other. Embedded Systems is not that easy.
You are having the same problem, so you have to use one of them.
Once I encountered a similar issue and I have to use a second Arduino board and then I sent data via serial port to the first Arduino.
jmacarthur
It appears that RTC.begin() is enabling register protection on a register that the I2S needs. The fix is to initialize the I2S before the RTC -- at least that worked for me.
mikeysklar
That is cool that you got it going by changing the init order.
Does the time hold and sound continue to work as long as I2S is initialized before RTC?
jmacarthur
Apparently. I'll mess around with it and let you know if there's any trouble.
Return to “Arduino”
