[Starting] Uploading sketch 'examples\AdafruitMacropadDemo.ino'
[Warning] Output path is not specified. Unable to reuse previously compiled files. Build will be slower. See README.
Loading configuration...
Initializing packages...
Preparing boards...
Verifying...
Uploading...
Resetting COM9
Converting to uf2, output size: 165888, start address: 0x2000
No drive to deploy.
An error occurred while uploading the sketch
IntelliSense configuration already up to date. To manually rebuild your IntelliSense configuration run "Ctrl+Alt+I"
[Error] Uploading sketch 'examples\AdafruitMacropadDemo.ino': Exit with code=1
I would seriously appreciate any help debugging this!
