Woodworker here. Looking to mount these components on the underside of a cornhole board and would like to use an arcade style button on the zero (random) trigger to play various loaded sound bites.
Adafruit fx sound board 2x2 watt amp - https://www.adafruit.com/product/2210
Speakers - 40 mm diamter 4ohm 3 watt - https://www.adafruit.com/product/3968
4 x AA battery holder - https://www.adafruit.com/product/830
30MM Arade buttone - https://www.adafruit.com/product/3487
And 22 gauge wire.
This is out of my realm and would appreciate your help and input. Is there a control knob i should include to control volume?
Thank you!!!
nOoB question. Help with component viability?
- adafruit_support_bill
Re: nOoB question. Help with component viability?
Those components should do the job.
https://learn.adafruit.com/adafruit-aud ... 1386546-10
Volume control for the FX board is via up/down buttons. Any pair of momentary pushbuttons will work for that. Connect to the VOL +/- pins as described here:is there a control knob i should include to control volume?
- Sus4
Thanks for the reply.
Will everything else work together fine?
Those should work together. Although, with a 4xAA battery holder you should use rechargeable NiMH cells. If you want to use regular Alkaline cells, you should use a 3xAA holder as described in the guide.
https://learn.adafruit.com/adafruit-aud ... -2427299-5
- Sus4
Thank you for the input. This is what I was looking for!
