Is Software Serial compatible with the QT Py?
We are currently using the Serial1 port on a QT py, but would like to map the MISO and MOSI pins to a Serial2 port. I tried to use SoftwareSerial but it cannot find that library. Is Software Serial not compatible with the QT Py on Arduino?
Thanks in advance for the assistance!
Is the Software Serial Library compatible with the QT Py?
- Simetri_Nick
- mikeysklar
Re: Is the Software Serial Library compatible with the QT Py
Assuming you are on a QtPy M0 you should be able to use SERCOM to map in a UART over the SPI pins.
