help using Keyboard.press triggered by a ping sensor
Davessi
Post by Davessi »
Hi Forum,
Looking for some help on a tricky project. I have been dabbling with Arduino for simple projects, but this one has me stumped. I need to be able to toggle a video to play at a distance of 5' or less and a different video at 6' and further. I can get the ping sensor to do the simple function of reading the distance and displaying in the serial monitor. That all works fine and I can get the 'Keyboard.press and Keyboard.release functions to work too. That said, I have the issue of the Void Loop constantly activating the keyboard and printing out A's or D's (see code below). I simplified my code so I would just be working within 20 cm and I could use my hand to test the functions.
I am using a program on my PC that uses mapped keyboard presses to trigger the playback of the video files. For example, if i hit the 'D' key on my keyboard it will play a certain video and if I hit the 'A' key it will play a different video. Works great when it's a human pressing the buttons. However, the Arduino (my code) keeps hitting the keys over and over and it restarts the videos.
Is there a way to still ping for the distance parameters (6' >= press 'A') and (5' <= press 'D') and toggle the keyboard one time?
#include <NewPing.h>
#include <Keyboard.h>
#define PING_PIN  12  // Arduino pin tied to both trigger and echo pins on the ultrasonic sensor.
#define MAX_DISTANCE 200 // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.
NewPing sonar(PING_PIN, PING_PIN, MAX_DISTANCE); // NewPing setup of pin and maximum distance.
  Serial.begin(115200); // Open serial monitor at 115200 baud to see ping results.
  delay(1000);                     // Wait 1s between pings.
  Serial.print("Ping: ");
  Serial.print(sonar.ping_cm()); // Send ping, get distance in cm and print result (0 = outside set distance range)
  Serial.println("cm");
Keyboard.begin();
 if (sonar.ping_cm()>= 21)
  Keyboard.press('A');
  delay(100);
  Keyboard.release('A');
  delay(6000);
 else if (sonar.ping_cm()<= 20){
  Keyboard.press('D');
  delay(100);
  Keyboard.release('D');
  delay(6000);
Keyboard.end();
Re: help using Keyboard.press triggered by a ping sensor
If you only want it to execute once, move all that code into your setup.
Davessi
Post by Davessi »
Hey Bill, thank you for the reply. I probably should have been more clear. I do need the program to loop and check the state of the ping distance, but instead of just printing keyboard characters in a stream, I would like for the keyboard.press to act more like a monetary push button.
For example, if the ping is > 20cm toggle character 'D' on/off and wait for a 30 sec video to play, BUT if the ping if <20cm toggle character 'A' on/off and wat for a 60 sec video. this is my dilemma.
Then you need to increase your delays. The parameter to the delay function is in milliseconds. Currently you are delaying by 6000 milliseconds which is just 6 seconds.
Davessi
Post by Davessi »
Thank you for helping me think through this ping sensor project. I have simplified the code and this works just fine. i have set a max limit on the sensor ping and dialed in to trigger my media player at 5' or less. I did use a delay for 14 sec. as a test with a short video loop.
my only REAL problem is I won't know how long these video will be until we actually build these kiosks. Some might be 1 minute and some might be 2 minutes. i just don't know at this point. I can probably program my media player to send out a 'keystroke' or ASCII character once the video is done playing. Can the Arduino read a keystroke or character through the USB port?
#define MAX_DISTANCE 300 // Maximum distance we want to ping for (in centimeters). Maximum sensor distance is rated at 400-500cm.
  delay(600);                     // Wait 1s between pings.
Keyboard.begin();
 //if (sonar.ping_cm()> 20)
  //Keyboard.press('A');
  //delay(100);
  //Keyboard.release('A');
  //delay(14000);
 if (sonar.ping_cm()<= 150){
  delay(100);
  delay(14000);
Keyboard.end();
Yes it can. Use Serial.Read();
https://www.arduino.cc/reference/en/lan ... rial/read/
Return to “Arduino”
