I2c multiplexer TCA9548A with the LTC4311 over arduino uno
physocean16
Post by physocean16 »
I am currently working on troubleshooting why my sht85 sensor values are not printing to the serial port. I am running four sht85 sensors via an arduino Uno which is connected to the TCA9548A multiplexer which is then extended/ boosted using the LTC4311 for each individual sensor. The Arduino Uno utilizes the Hitlego data logging shield with an electronics salon screw terminal attachment. I have verified that I can operate 4 sensors over a short distance and data log. In addition I can operate one sensor with the arduino Uno and LTC4311 over at least 3-4m length (last two images); however, the issue arises when I want to run 4 at once over the 3-4m length (Setup for the 1st image). To operate one sensor I use the standard sht-autodetect code provided by arduino; To operate all four sensors I run the longer code of the two posted.
I have also checked that I am providing the required 3.3V to the sensors as well and tested the connections for all of the components.
My wiring color coordination is as follows:
Ground = Black
Power = Red
SCL = Blue
SDA = Green
Do I need to also boost the TCA9548A? I believe I do not need to boost the multiplexer as it is merely assigning the addresses for the other sensors, but I could be wrong.....
Any suggestions or solutions to this issue would be greatly appreciated. My backup plan is to resort back to the arduino Nano with the a data logging shield which I have tested and was able to get good data for my project; however, trying to synch and operate 30 individual sensors at once is very time consuming.
# sht85-auto-detect code
#include <Wire.h>
#include "SHTSensor.h"
SHTSensor sht;
// To use a specific sensor instead of probing the bus use this command:
// SHTSensor sht(SHTSensor::SHT3X);
  // put your setup code here, to run once:
  Wire.begin();
  Serial.begin(115200);
  delay(1000); // let serial console settle
  if (sht.init()) {
      Serial.print("init(): success\n");
  } else {
      Serial.print("init(): failed\n");
  sht.setAccuracy(SHTSensor::SHT_ACCURACY_MEDIUM); // only supported by SHT3x
  // put your main code here, to run repeatedly:
  if (sht.readSample()) {
      Serial.print("Temperature:  ");
      Serial.print(sht.getTemperature(), 2);
      Serial.print(' ');
      Serial.print("RH: ");
      Serial.print(sht.getHumidity(), 2);
      Serial.print(' ');
      Serial.println();
  } else {
      Serial.print("Error in readSample()\n");
  delay(1000);
# this is the code that was written to run four sensors at once.
#include <Wire.h>
#include <SPI.h>
#include <SD.h>         // Include SD library
#include <RTClib.h>
//////////////// intiiliaze the 8 sensors in the box///////////////////////////////////
SHTSensor sht0;
SHTSensor sht1;
SHTSensor sht2;
SHTSensor sht3;
//SHTSensor sht4;
//SHTSensor sht5;
//SHTSensor sht6;
//SHTSensor sht7;
RTC_DS1307 RTC;
File dataFile;
byte busStatus;
const int chipSelect = 10; // specify the data logging pin onboard the box
#define TCAADDR 0x70
void tcaselect(uint8_t i) {
  if (i > 7) return;
  Wire.beginTransmission(TCAADDR);
  Wire.write(1 << i);
  Wire.endTransmission();
  while (!Serial);
    delay(1000);
    Wire.begin();
    Serial.begin(9600);
RTC.begin();
  RTC.adjust(DateTime((__DATE__), (__TIME__)));    //sets the RTC to the computer time when the sketch is loaded
   while (!Serial){
///////////// Initiliaze the sht85 sensors////////////////////////////////////////////
    tcaselect(0);
 if (sht0.init()) {
  } else {
      tcaselect(1);
 if (sht1.init()) {
  } else {
   tcaselect(2);
 if (sht2.init()) {
  } else {
     tcaselect(3);
 if (sht3.init()) {
  } else {
//    tcaselect(4);
// if (sht4.init()) {
//      Serial.print("init(): success\n");
//  } else {
//      Serial.print("init(): failed\n");
//      tcaselect(5);
// if (sht5.init()) {
//  } else {
//   tcaselect(6);
// if (sht6.init()) {
//  } else {
//     tcaselect(7);
// if (sht7.init()) {
//  } else {
  //////////// Initiliazing the SD card and the RTC for time stamping samples/////////////////////////////////////
   Serial.print("Initializing SD card...");
  if (!SD.begin(chipSelect)) {
    Serial.println("initialization failed!");
    while (1);
      Serial.println("initialization done.");
  Serial.println("Initializing RTC...");
  if(!RTC.begin()) {
    Serial.println("Couldn't find RTC");
  if (! RTC.isrunning())   {
        Serial.println("RTC is NOT running!");
           while(1);
                 Serial.println("RTC initialization done.");
  DateTime now = DateTime(RTC.now().unixtime()+46);
dataFile = SD.open("sensor1.txt", FILE_WRITE);
if(dataFile) {
    tcaselect(0);
  if (sht0.readSample()) {
      Serial.print("Temperature1:  ");
      Serial.print(sht0.getTemperature(), 2);
      Serial.print(' ');
      Serial.print("RH1: ");
      Serial.print(sht0.getHumidity(), 2);
      Serial.print(' ');
  } else {
    tcaselect(1);
  if (sht1.readSample()) {
      Serial.print("Temperature2:  ");
      Serial.print(sht1.getTemperature(), 2);
      Serial.print(' ');
      Serial.print("RH2: ");
      Serial.print(sht1.getHumidity(), 2);
      Serial.print(' ');
  } else {
      tcaselect(2);
  if (sht2.readSample()) {
      Serial.print("Temperature3:  ");
      Serial.print(sht2.getTemperature(), 2);
      Serial.print(' ');
      Serial.print("RH3: ");
      Serial.print(sht2.getHumidity(), 2);
      Serial.print(' ');
  } else {
  tcaselect(3);
  if (sht3.readSample()) {
      Serial.print("Temperature4:  ");
      Serial.print(sht3.getTemperature(), 2);
      Serial.print(' ');
      Serial.print("RH4: ");
      Serial.print(sht3.getHumidity(), 2);
      Serial.print(' ');
       } else {
//   tcaselect(4);
//  if (sht4.readSample()) {
//      Serial.print("Temperature5:  ");
//      Serial.print(sht4.getTemperature(), 2);
//      Serial.print(' ');
//      Serial.print("RH5: ");
//      Serial.print(sht4.getHumidity(), 2);
//  } else {
//      Serial.print("Error in readSample()\n");
//    tcaselect(5);
//  if (sht5.readSample()) {
//      Serial.print("Temperature6:  ");
//      Serial.print(sht5.getTemperature(), 2);
//      Serial.print("RH6: ");
//      Serial.print(sht5.getHumidity(), 2);
//  } else {
//      tcaselect(6);
//  if (sht6.readSample()) {
//      Serial.print("Temperature7:  ");
//      Serial.print(sht6.getTemperature(), 2);
//      Serial.print("RH7: ");
//      Serial.print(sht6.getHumidity(), 2);
//  } else {
//        tcaselect(7);
//  if (sht7.readSample()) {
//      Serial.print("Temperature8:  ");
//      Serial.print(sht7.getTemperature(), 2);
//      Serial.print("RH8: ");
//      Serial.print(sht7.getHumidity(), 2);
//       } else {
Serial.print(' ');
Serial.print(now.year(), DEC);
Serial.print('/');
Serial.print(now.month(), DEC);
Serial.print('/');
Serial.print(now.day(), DEC);
Serial.print(' ');
Serial.print(now.hour(), DEC);
Serial.print(':');
Serial.print(now.minute(), DEC);
Serial.print(':');
Serial.print(now.second(), DEC);
Serial.println();
///////////////////// DATA LOGGING TO SD CARD LINES ////////////////////////////
dataFile.print("  RH1: ");
dataFile.print(sht0.getHumidity(), 2);
dataFile.print("");
dataFile.print("  Temperature1:  ");
dataFile.print(sht0.getTemperature(),2);
dataFile.print("  RH2: ");
dataFile.print(sht1.getHumidity(), 2);
dataFile.print("");
dataFile.print("  Temperature2:  ");
dataFile.print(sht1.getTemperature(),2);
dataFile.print("  RH3: ");
dataFile.print(sht2.getHumidity(), 2);
dataFile.print("");
dataFile.print("  Temperature3:  ");
dataFile.print(sht2.getTemperature(),2);
dataFile.print("  RH4: ");
dataFile.print(sht3.getHumidity(), 2);
dataFile.print("");
dataFile.print("  Temperature4:  ");
dataFile.print(sht3.getTemperature(),2);
//dataFile.print("  RH5: ");
//dataFile.print(sht4.getHumidity(), 2);
//dataFile.print("");
//dataFile.print("  Temperature5:  ");
//dataFile.print(sht4.getTemperature(),2);
//dataFile.print("  RH6: ");
//dataFile.print(sht5.getHumidity(), 2);
//dataFile.print("  Temperature6:  ");
//dataFile.print(sht5.getTemperature(),2);
//dataFile.print("  RH7: ");
//dataFile.print(sht6.getHumidity(), 2);
//dataFile.print("  Temperature7:  ");
//dataFile.print(sht6.getTemperature(),2);
//dataFile.print("  RH8: ");
//dataFile.print(sht7.getHumidity(), 2);
//dataFile.print("  Temperature8:  ");
//dataFile.print(sht7.getTemperature(),2);
////////////////// BEGIN PRINTING THE RTC TIME STAMPS OF SAMPLES///////////////////////////////////////
dataFile.print(' ');
dataFile.print(now.year(), DEC);
dataFile.print('/');
dataFile.print(now.month(), DEC);
dataFile.print(now.day(), DEC);
dataFile.print(now.hour(), DEC);
dataFile.print(':');
dataFile.print(now.minute(), DEC);
dataFile.print(now.second(), DEC);
dataFile.println();
dataFile.close();
delay(1000);
3 sensor arduino uno box.jpg (600.96 KiB) Viewed 433 times
Simplified Uno sensor.jpg (795.63 KiB) Viewed 433 times
simplified Uno booster.jpg (832.65 KiB) Viewed 433 times
Return to “Arduino”
