nRF52 using Adafruit_LittleFs for storing cal variables
argotwo
Post by argotwo »
Hi
I would like to store a couple of persistent variables in the itsybitsy NRF52840's QSPI Flash and am trying trying to use/understand the LittleFS example here: https://github.com/adafruit/Adafruit_nR ... _ReadWrite
The sketch code that I can't duplicate for simple variable storage is this (code snip from Internal_ReadWrite.ino example):
 // Initialize Internal File System
  InternalFS.begin();
  file.open(FILENAME, FILE_O_READ);
  // file existed
  if ( file )
    Serial.println(FILENAME " file exists");
    uint32_t readlen;
    char buffer[64] = { 0 };
    readlen = file.read(buffer, sizeof(buffer));
    buffer[readlen] = 0;
    Serial.println(buffer);
    file.close();
  }else
    Serial.print("Open " FILENAME " file to write ... ");
    if( file.open(FILENAME, FILE_O_WRITE) )
      Serial.println("OK");
      file.write(CONTENTS, strlen(CONTENTS));
      file.close();
    }else
      Serial.println("Failed!");
  Serial.println("Done");
Key gaps in my understanding are:
"file.open" is straightforward ... open the file.
"FILENAME" ... the name of the file previously defined (example uses: "/adafruit.txt")
But what does "FILE_O_READ" do?
Similarly for "file.open(FILENAME, FILE_O_WRITE)" what is FILE_O_WRITE doing?
I'm just wanting to store two simple integer calibration variables, but can't work out how to use Adafruit LittleFS to write or read the persistent data to an int variable in my sketch.
Any advice or links to examples would be very appreciated!
Re: nRF52 using Adafruit_LittleFs for storing cal variables
It tells the file system that you want to open the file for read access.
That tells the file system that you want to open the file for write access.
See the example here:
https://github.com/adafruit/Adafruit_nR ... dWrite.ino
argotwo
Post by argotwo »
Thank you Bill :)
Lucky there is no such thing as a silly question - pretty obvious!
For some reason, I was expecting to see that part of the command to outside the brackets.
Return to “Arduino”
