Adafruit SFX won't connect to Arduino (UART Mode)
jonah8181
Post by jonah8181 »
IMG_0502 (1).jpeg (257.64 KiB) Viewed 987 times
IMG_0500 (1).jpeg (297.24 KiB) Viewed 987 times
I recently purchased an audioFX sound board with built in amp.
It works if I attach a trigger to ground. But when I try to control it with my Arduino, using the example code from the library, the Serial Monitor reports:
⸮⸮Adafruit Sound Board!
Not found
I have power on the board.
Vin goes to 5v
ground to ground
RST is plugged into 4
RX is in 6
Tx in 5
UG goes to ground
There's a bit of extra solder on RX but it doesn't seem to be contacting anything it shouldn't.
Any advice on what to do next?
Here's the code:
Menu driven control of a sound board over UART.
Commands for playing by # or by name (full 11-char name)
Hard reset and List files (when not playing audio)
Vol + and - (only when not playing audio)
Pause, unpause, quit playing (when playing audio)
Current play time, and bytes remaining & total bytes (when playing audio)
Connect UG to ground to have the sound board boot into UART mode
a
#include <SoftwareSerial.h>
#include "Adafruit_Soundboard.h"
// Choose any two pins that can be used with SoftwareSerial to RX & TX
#define SFX_TX 5
#define SFX_RX 6
// Connect to the RST pin on the Sound Board
#define SFX_RST 4
// You can also monitor the ACT pin for when audio is playing!
// we'll be using software serial
SoftwareSerial ss = SoftwareSerial(SFX_TX, SFX_RX);
// pass the software serial to Adafruit_soundboard, the second
// argument is the debug port (not used really) and the third
// arg is the reset pin
Adafruit_Soundboard sfx = Adafruit_Soundboard(&ss, NULL, SFX_RST);
// can also try hardware serial with
// Adafruit_Soundboard sfx = Adafruit_Soundboard(&Serial1, NULL, SFX_RST);
Serial.begin(115200);
Serial.println("Adafruit Sound Board!");
// softwareserial at 9600 baud
ss.begin(9600);
// can also do Serial1.begin(9600)
if (!sfx.reset()) {
Serial.println("Not found");
while (1);
Serial.println("SFX board found");
flushInput();
Serial.println(F("What would you like to do?"));
Serial.println(F("[r] - reset"));
Serial.println(F("[+] - Vol +"));
Serial.println(F("[-] - Vol -"));
Serial.println(F("[L] - List files"));
Serial.println(F("[P] - play by file name"));
Serial.println(F("[#] - play by file number"));
Serial.println(F("[=] - pause playing"));
Serial.println(F("[>] - unpause playing"));
Serial.println(F("[q] - stop playing"));
Serial.println(F("[t] - playtime status"));
Serial.println(F("> "));
while (!Serial.available());
char cmd = Serial.read();
flushInput();
switch (cmd) {
case 'r': {
if (!sfx.reset()) {
Serial.println("Reset failed");
break;
case 'L': {
uint8_t files = sfx.listFiles();
Serial.println("File Listing");
Serial.println("========================");
Serial.println();
Serial.print("Found "); Serial.print(files); Serial.println(" Files");
for (uint8_t f=0; f<files; f++) {
Serial.print(f);
Serial.print("\tname: "); Serial.print(sfx.fileName(f));
Serial.print("\tsize: "); Serial.println(sfx.fileSize(f));
break;
case '#': {
Serial.print("Enter track #");
uint8_t n = readnumber();
Serial.print("\nPlaying track #"); Serial.println(n);
if (! sfx.playTrack((uint8_t)n) ) {
Serial.println("Failed to play track?");
break;
case 'P': {
Serial.print("Enter track name (full 12 character name!) >");
char name[20];
readline(name, 20);
Serial.print("\nPlaying track \""); Serial.print(name); Serial.print("\"");
if (! sfx.playTrack(name) ) {
break;
case '+': {
Serial.println("Vol up...");
uint16_t v;
if (! (v = sfx.volUp()) ) {
Serial.println("Failed to adjust");
} else {
Serial.print("Volume: "); Serial.println(v);
break;
case '-': {
Serial.println("Vol down...");
uint16_t v;
if (! (v=sfx.volDown()) ) {
} else {
Serial.println(v);
break;
case '=': {
Serial.println("Pausing...");
if (! sfx.pause() ) Serial.println("Failed to pause");
break;
case '>': {
Serial.println("Unpausing...");
if (! sfx.unpause() ) Serial.println("Failed to unpause");
break;
case 'q': {
Serial.println("Stopping...");
if (! sfx.stop() ) Serial.println("Failed to stop");
break;
case 't': {
Serial.print("Track time: ");
uint32_t current, total;
if (! sfx.trackTime(&current, &total) ) Serial.println("Failed to query");
Serial.print(current); Serial.println(" seconds");
break;
case 's': {
Serial.print("Track size (bytes remaining/total): ");
uint32_t remain, total;
if (! sfx.trackSize(&remain, &total) )
Serial.print(remain); Serial.print("/"); Serial.println(total);
break;
/************************ MENU HELPERS ***************************/
void flushInput() {
// Read all available serial input to flush pending data.
uint16_t timeoutloop = 0;
while (timeoutloop++ < 40) {
while(ss.available()) {
ss.read();
timeoutloop = 0; // If char was received reset the timer
delay(1);
char readBlocking() {
return Serial.read();
uint16_t readnumber() {
uint16_t x = 0;
char c;
while (! isdigit(c = readBlocking())) {
//Serial.print(c);
Serial.print(c);
x = c - '0';
while (isdigit(c = readBlocking())) {
Serial.print(c);
x *= 10;
x += c - '0';
return x;
uint8_t readline(char *buff, uint8_t maxbuff) {
uint16_t buffidx = 0;
while (true) {
if (buffidx > maxbuff) {
break;
if (Serial.available()) {
char c = Serial.read();
//Serial.print(c, HEX); Serial.print("#"); Serial.println(c);
if (c == '\r') continue;
if (c == 0xA) {
if (buffidx == 0) { // the first 0x0A is ignored
continue;
buff[buffidx] = 0; // null term
return buffidx;
buff[buffidx] = c;
buffidx++;
return buffidx;
jonah8181
Re: Adafruit SFX won't connect to Arduino (UART Mode)
Post by jonah8181 »
Ah. I solved it! It seems on the Mega, I had to use
18 for TX
19 for RX
and then use the optional "Serial1" code that comes commented out in the sketch instead of "SS"
buildmyhobby
Post by buildmyhobby »
I am using an Arduino Nano33BLE which doesn't like the SoftwareSeial.h library. Changing to Serial1 in the example sketch allows compiling.
However I am trying to write to Serial1 to call tracks by number using the suggested format but I get the following error:
Arduino: 1.8.16 (Windows Store 1.8.51.0) (Windows 10), Board: "Arduino Nano 33 BLE"
menucommands_not_using_software_serial:27:25: error: stray '\' in program
Serial1.write(PT09 WAV\n);
menucommands_not_using_software_serial:189:29: error: stray '\' in program
C:\Users\KevB\Documents\Arduino\menucommands_not_using_software_serial\menucommands_not_using_software_serial.ino:189:21: note: suggested alternative: 'P1_9'
P1_9
exit status 1
Can someone please explain and suggest a workaround please. I've been trying for a week but can't find any info on using these boards with Nano33BLE series.
I also don't need any special functions just a plain call in a track to be played when a 'Case" statement is true in my code.
Hence why I am wanting to use: Serial1.write(PT09 WAV\n); is the the correct way, if not please explain.
Thanks in advance.
buildmyhobby
SOLUTION1: The Nano33BLE did not like this format. It works with Serial1.write("#9"); the \n scares it too so delete that.
SOLUTION2: To upload files or to open the board as a USB with your PC once board is wired up to an Arduino:
Put a switch inline with the GND to UG connection and open the contacts to float the connection and this will allow USB connection to a PC, recognise the device as a USB drive and now you can upload your files. No need to disconnect the board from your Arduino board.
Return to “Arduino”
