HTTPCLient does not have a type ERROR
_phillip
Post by _phillip »
I have tried to get this test sketch to work but have never been able to overcome the following error:
"'HTTPClient' does not name a type; did you mean 'HttpClient'?"
I probably have an excess of #include libraries added to try an solve this error. In my research I have come across several comments about their being several 'HTTPClient.h' and 'HttpClient.h', which appears to be true. This is confusing to say the least. Whether this is the problem, I am not certain.
If I add: #include HttpClient.h (note lower case 'ttp', then the error becomes -
If anyone can shed some light on this I would be very grateful. Here is my test sketch:
  // test Rui sketch
  // cannot overcome following error:
  //  'HTTPClient' does not name a type; did you mean 'HttpClient'?
  #include <b64.h>
  #include <Wire.h>
  #include <Adafruit_Sensor.h>
  #include <Adafruit_BME280.h>
  #include <WiFi101.h>
  #include "Adafruit_MQTT.h"
  #include "Adafruit_MQTT_Client.h"
  #include <SPI.h>
  #include <WiFi.h>
  #include <HTTPClient.h>
  // My code moved from loop() ...
  WiFiClient client;
  HTTPClient http;
// Replace with your network credentials
const char* ssid     = "REPLACE_WITH_YOUR_SSID";
const char* password = "REPLACE_WITH_YOUR_PASSWORD";
const char* serverName = "http://redristracards.com/post-data.php";
  String apiKeyValue = "tPmAT5Ab3j7F9";
  Serial.begin(115200);
  WiFi.begin(ssid, password);
  Serial.println("Connecting");
  while(WiFi.status() != WL_CONNECTED) {
    delay(500);
    Serial.print(".");
  Serial.println("");
  Serial.print("Connected to WiFi network with IP Address: ");
  Serial.println(WiFi.localIP());
  // (you can also pass in a Wire library object like &Wire2)
  bool status = bme.begin(0x76);
  if (!status) {
    Serial.println("Could not find a valid BME280 sensor, check wiring or change I2C address!");
    while (1);
  //Check WiFi connection status
  if(WiFi.status()== WL_CONNECTED){
    // Your Domain name with URL path or IP address with path
    http.begin(client, serverName);
    // Specify content-type header
    http.addHeader("Content-Type", "application/x-www-form-urlencoded");
    // Prepare your HTTP POST request data
    String httpRequestData = "api_key=" + apiKeyValue + "&value1=" + String(bme.readTemperature())
                           + "&value2=" + String(bme.readHumidity()) + "&value3=" + String(bme.readPressure()/100.0F) + "";
    Serial.print("httpRequestData: ");
    Serial.println(httpRequestData);
    if (httpResponseCode>0) {
      Serial.print("HTTP Response code: ");
      Serial.println(httpResponseCode);
    else {
      Serial.print("Error code: ");
    // Free resources
    http.end();
  else {
    Serial.println("WiFi Disconnected");
  //Send an HTTP POST request every 30 seconds
  delay(30000);
Thank you.
Re: HTTPCLient does not have a type ERROR
The capitalization of the #include statement is irrelevant. It is just a file name. What matters is the capitalization of your declaration:
  HTTPClient http;
That should match the capitalization of the class definition in the header file:
class HttpClient : public Client
_phillip
Post by _phillip »
Thank you. I will try to implement that info in the sketch.
I appreciate your help.
Return to “Arduino”
