I have 32 Neotrellis boards soldered together in a 4x8 grid https://learn.adafruit.com/adafruit-neotrellis
If I load only 1 board the interrupt function works fine but if I load the 32 boards (multitrellis) the behaviour is erratic.
For example I have this in the Loop function
if (!digitalRead(INT_PIN)) {
trellis.read();
Serial.println("Hello");
Someone noticed this difference beetwen Neotrellis (only loading 1 board) and Multitrellis .
This is the 1 board LoopI dug into the libraries a bit and it turns out that you have the option of polling or not for a single trellis board, but once you switch over to the multitrellis class, it is simply .read()
trellis.read(false);
Another thing I dont get is if I load this
Here is the full code for the multitrellis
/* This example shows basic usage of the NeoTrellis
with the interrupt pin.
The buttons will light up various colors when pressed.
#include "Adafruit_NeoTrellis.h"
Adafruit_NeoTrellis trellis;
#define INT_PIN 8
// Input a value 0 to 255 to get a color value.
// The colors are a transition r - g - b - back to r.
uint32_t Wheel(byte WheelPos) {
if(WheelPos < 85) {
return trellis.pixels.Color(WheelPos * 3, 255 - WheelPos * 3, 0);
} else if(WheelPos < 170) {
WheelPos -= 85;
return trellis.pixels.Color(255 - WheelPos * 3, 0, WheelPos * 3);
} else {
WheelPos -= 170;
return trellis.pixels.Color(0, WheelPos * 3, 255 - WheelPos * 3);
//define a callback for key presses
TrellisCallback blink(keyEvent evt){
if(evt.bit.EDGE == SEESAW_KEYPAD_EDGE_RISING)
trellis.pixels.setPixelColor(evt.bit.NUM, Wheel(map(evt.bit.NUM, 0, trellis.pixels.numPixels(), 0, 255))); //on rising
else if(evt.bit.EDGE == SEESAW_KEYPAD_EDGE_FALLING)
trellis.pixels.setPixelColor(evt.bit.NUM, 0); //off falling
trellis.pixels.show();
return 0;
Serial.begin(9600);
//while(!Serial);
pinMode(INT_PIN, INPUT);
if(!trellis.begin()){
Serial.println("could not start trellis");
while(1);
else{
Serial.println("trellis started");
//activate all keys and set callbacks
for(int i=0; i<NEO_TRELLIS_NUM_KEYS; i++){
trellis.activateKey(i, SEESAW_KEYPAD_EDGE_RISING);
trellis.activateKey(i, SEESAW_KEYPAD_EDGE_FALLING);
trellis.registerCallback(i, blink);
//do a little animation to show we're on
for(uint16_t i=0; i<trellis.pixels.numPixels(); i++) {
trellis.pixels.setPixelColor(i, Wheel(map(i, 0, trellis.pixels.numPixels(), 0, 255)));
delay(50);
trellis.pixels.setPixelColor(i, 0x000000);
delay(50);
if(!digitalRead(INT_PIN)){
trellis.read();
delay(2);
