I'm looking for an Arduino simulator that supports the following
The following hardware
Arduino Uno
L298N - Or anything closely resembling this motor controller
HC-12 - If this is not available then at least the ability to access the serial monitor
And the ability to run the following sketch at https://github.com/joneal92110/an-ardur ... urover.ino
If anyone can help me with this, that would be great.
I'm basically working with hardware that looks similar like this (broken out) and I'd like to be able to create a prototype like this online or on a simulator. I'm quite flexible. I know that not everything in the real world can be created online so I'm looking for any ideas.
Jeremiah O'Neal
Robotics Instructor
- jonealroboticsinstructor
- jim_lee
Re: looking for an Arduino simulator
The best simulator I've run across is the wokwi one. https://wokwi.com The UI is still a little rough, but its simulation is WAY better than anything else I've seen. And, if you need a change? You can purchase it! You can basically say "I need X done". If they agree, they will put your X on the list. Now, anyone can "vote" with dollars to move that up the priority list. Whatever ends up at the top, they work on. This is how I was able to get the Adafruit 1947 touch screen & an SD card simulated on there for my stuff.
-jim lee
-jim lee
- mikeysklar
Nice summary of modern Arduino simulators here (if you can tolerate the ads).
https://all3dp.com/2/best-arduino-simul ... e-offline/
