I don't think we have a code example for the CPX doing proximity sensing, but I can point you at some straight C code that might help you get it going with Arduino.
#include <Adafruit_CircuitPlayground.h>
#if !defined(ARDUINO_SAMD_CIRCUITPLAYGROUND_EXPRESS)
#error "Infrared support is only for the Circuit Playground Express, it doesn't work with other boards."
#endif
//Setup everything
CircuitPlayground.begin();
pinMode(CPLAY_IR_EMITTER, OUTPUT);
digitalWrite(CPLAY_IR_EMITTER, LOW);
pinMode(A8, INPUT);
pinMode(13, OUTPUT);
Serial.begin(19200);
int IR;
void on() {
//Turn all NeoPixels on
CircuitPlayground.setPixelColor(0, 255, 255, 255);
CircuitPlayground.setPixelColor(1, 255, 255, 255);
CircuitPlayground.setPixelColor(2, 255, 255, 255);
CircuitPlayground.setPixelColor(3, 255, 255, 255);
CircuitPlayground.setPixelColor(4, 255, 255, 255);
CircuitPlayground.setPixelColor(5, 255, 255, 255);
CircuitPlayground.setPixelColor(6, 255, 255, 255);
CircuitPlayground.setPixelColor(7, 255, 255, 255);
CircuitPlayground.setPixelColor(8, 255, 255, 255);
CircuitPlayground.setPixelColor(9, 255, 255, 255);
void off() {
//Turn all NeoPixels off
CircuitPlayground.setPixelColor(0, 0, 0, 0);
CircuitPlayground.setPixelColor(1, 0, 0, 0);
CircuitPlayground.setPixelColor(2, 0, 0, 0);
CircuitPlayground.setPixelColor(3, 0, 0, 0);
CircuitPlayground.setPixelColor(4, 0, 0, 0);
CircuitPlayground.setPixelColor(5, 0, 0, 0);
CircuitPlayground.setPixelColor(6, 0, 0, 0);
CircuitPlayground.setPixelColor(7, 0, 0, 0);
CircuitPlayground.setPixelColor(8, 0, 0, 0);
CircuitPlayground.setPixelColor(9, 0, 0, 0);
void gray(int val) {
//Turn all NeoPixels to a percent of white
CircuitPlayground.setPixelColor(0, val, val, val);
CircuitPlayground.setPixelColor(1, val, val, val);
CircuitPlayground.setPixelColor(2, val, val, val);
CircuitPlayground.setPixelColor(3, val, val, val);
CircuitPlayground.setPixelColor(4, val, val, val);
CircuitPlayground.setPixelColor(5, val, val, val);
CircuitPlayground.setPixelColor(6, val, val, val);
CircuitPlayground.setPixelColor(7, val, val, val);
CircuitPlayground.setPixelColor(8, val, val, val);
CircuitPlayground.setPixelColor(9, val, val, val);
void mid() {
//Turn all NeoPixels to gray
gray(64);
bool prev;
bool isOn;
long lastActivation;
if (CircuitPlayground.slideSwitch()) {
//Run if mode is proximity
//Turn off LED to show proximity mode
digitalWrite(13, LOW);
//Don't spend too much time with IR LED on
delay(200);
//Turn IR LED on
digitalWrite(CPLAY_IR_EMITTER, HIGH);
//Let analog val set
delay(50);
//Read proximity
IR = analogRead(A8);
//Turn off IR LED
//Print proximity so you can plot
Serial.println(map(IR, 930, 970, 0, 100));
//Make val into a more easy to manage number
IR = map(IR, 930, 970, 0, 100);
if (IR > 70) {
//Close to object
if (!prev) {
//Close to object but not when ran last loop
mid();
prev = true;
lastActivation = millis();
} else {
//Close to object in last loop and this loop
on();
prev = true;
} else {
//Not close to object
if (millis() - lastActivation < 10000 && millis() - lastActivation > 9700) {
//Been close to object in 9700-10000 milliseconds
mid();
prev = false;
} else if (millis() - lastActivation > 10000) {
//Haven't been close to object within 10 seconds
off();
prev = false;
} else {
//Fix bug for when you only activate the IR sense in 1 loop so the NeoPixels are at mid bright for the time
on();
} else {
//Manual mode, so show LED and push back lastActivation
digitalWrite(13, HIGH);
lastActivation = -50000;
if (CircuitPlayground.rightButton()) {
//On button is pressed
isOn = true;
} else if (CircuitPlayground.leftButton()) {
//Off button is pressed and on button isn't pressed
isOn = false;
//Manage NeoPixels
if (isOn) {
on();
} else {
off();
