The kit:
Arduino Nano 33 IOT
27 Warm White individual Adafruit NeoPixels
27 LED Breakout PCB's
The project:
A customer made Telecaster with embedded LED's that did a variety of things.
Link to what it looked like working:
https://www.instagram.com/p/CFe_0fgncgW/
No link to how it went sideways, but it stopped walking through the LED's in the right order, things just went wonky on it. I thought I may had drilled through one of the wires, but all the lights light up individually. Code for the full project is here: https://github.com/lanapalooza/fathomcaster
So, in order to not eat an elephant in a single bite, I've simplified things.
Since I can't take the lights out of the guitar, I reproduced the setup on my bench, but even more simple.
Using the same Nano 33 IOT, I soldered up some more NeoPixels, wrote the simplest of sketch files and I'm getting similar behaviour. That is I can't light up Pixel's 8 and 9 in my string on the bench... I've taken the pixels from the 8 and 9 spot and moved them to the 6 and 7 spot and they work fine, I don't have a capacitor in place, but I do have a 470Ohm resistor on the data line, whether it is there or no the behaviour is the same. I'm running the latest Libraries on the Nano 33 IOT.
This is what my code looks like:
#include <SPI.h>
// Which pin on the Arduino is connected to the NeoPixels?
#define LED_PIN 6 // On Trinket or Gemma, suggest changing this to 1
// How many NeoPixels are attached to the Arduino?
#define N_PIXELS 10 // Popular NeoPixel ring size
Adafruit_NeoPixel strip = Adafruit_NeoPixel(N_PIXELS, LED_PIN, NEO_GRB + NEO_KHZ800);
// These lines are specifically to support the Adafruit Trinket 5V 16 MHz.
// Any other board, you can remove this part (but no harm leaving it):
strip.begin();
strip.clear(); // Set all pixel colors to 'off'
strip.show();
for (int i = 0; i <= 10; i++) {
strip.setPixelColor(i, 10, 10, 10);
strip.show();
delay(200);
Serial.println(i);
for (int i = 10; i >= 0; i--) {
strip.setPixelColor(i, 0, 0, 0);
strip.show();
delay(200);
Serial.println(i);
