I have been struggling to 'do the right thing', laughing. Years ago I used a DUE and a OLED_NHD-1.5-128128 for a project. At that time I also had a FPGA in the design and choose
to use the OLED parallel 6800 interface rather than the SPI. We can argue about if that was smart. But anyway I ended up hacking the Adafruit_SSD1351 library horribly. I was not proud but it did work. Now I am at it again with a similar project trying to be the professional that I am not,... (Yes I am an EE) I have a fair mastery of C but I am NOT a master of C++.
So I am again using the parallel interface now connected to a Pi Pico. I have written a bunch of PIO code etc and managed to test the -driver- which works. But NOW what to do ?
I need to interface it to the Adafruit_GFX , Adafruit_SSD1351 libraries without making a total mess of them. In fact I WANT to "do the right thing" and - override - a method in
Adafruit_SPITFT which is part of the class hierarchy for the Adafruit_SSD1351 class. The method is the void sendCommand(uint8_t , uint8_t *, uint8_t ) function.
Recall I mentioned I am not a C++ guru,... but via hours of trial and error, internet searches etc I - think - I know the problem, and low - for once it may not be my problem,...
I have been attempting to override sendCommand but get this error:
'void OLED_LowLevelDriver::sendCommand(uint8_t, uint8_t*, uint8_t)' marked 'override', but does not override
If all those gurus on the internet are correct this error is because the sendCommand function is not marked virtual in the Adafruit_SPITFT class.
Here I try to override,
#include "Adafruit_SSD1351.h"
class OLED_LowLevelDriver : public Adafruit_SSD1351 {
public:
void sendCommand(uint8_t , uint8_t *, uint8_t ) override ;
void OLED_LowLevelDriver::sendCommand(uint8_t commandByte, uint8_t *dataBytes, uint8_t numDataBytes) {
// some code
Also the instantiation:
OLED_LowLevelDriver oled = OLED_LowLevelDriver(128, 128);
Being a C++ dummy, I lay myself at your feet and humbly request:
1) is my analysis correct?
2) if so would Adafruit please modify the Adafruit_SPITFT so that sendCommand may be overriden?
Cheers Dan
