Nokia 5110 LCD screen with Arduino MKR WAN 1310
paulrose
Post by paulrose »
Hi there,
I have a Nokia 5110 LCD screen attached to my Arduino MKR WAN 1310. It prints text in landscape just fine, over the landscape 6 rows. But when I rotate the screen to portrait the text continues to print on 6 rows, and not the full 12 rows? So only the top half of the screen is being printed on, with the bottom half left blank? I would have thought the bottom half of the screen would display my text? So that the full 12 rows in portrait would print text? Is this behaviour normal?
Thanks alot.
Paul
mikeysklar
Re: Nokia 5110 LCD screen with Arduino MKR WAN 1310
Post by mikeysklar »
Paul can you post the code you are running? I’m curious to see which library and resolution settings the screen is being initialized with.
paulrose
Post by paulrose »
Hi mikey,
Here is the code I'm using. Thanks for the help!
Paul
#include <Keypad.h>
#include <SPI.h>
#include <LoRa.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_PCD8544.h>
Adafruit_PCD8544 display = Adafruit_PCD8544(1, 2, 3, 4, 5);         //specifies which Arduino pins are connected to the LCD’s CLK, Din, D/C, CE and RST pin.
  Serial.begin(9600);
  display.begin();                                   //Initialize Display
  display.setContrast(57);                           //57
  display.setRotation(1);                            //0, 1, 2, or 3.
  display.setTextSize(2);
  display.setTextColor(BLACK);
  display.setTextWrap(true);
  display.clearDisplay();
  display.setCursor(0,0);                            //0, 0, 13, 15.  0 = column. 0 = row. 13 = width. 15 = deep.
  display.print("1");
  display.setCursor(18,0);
  display.print("2");
  display.setCursor(36,0);
  display.print("3");
  display.setCursor(0,21);
  display.print("4");
  display.setCursor(18,21);
  display.print("5");
  display.setCursor(36,21);                //34
  display.print("6");
  display.setCursor(0,42);
  display.print("7");
  display.setCursor(18,42);
  display.print("8");
  display.setCursor(36,42);
  display.print("9");
  display.setCursor(0,69);
  display.print("");
  display.setCursor(18,69);
  display.print("");
  display.setCursor(36,57);
  display.print("");
  display.display();
mikeysklar
@paulrose,
I see you opened a github issue with the library which is a good thing.
https://github.com/adafruit/Adafruit-PC ... /issues/62
When you run the demo code do you see the rotation working? I see it is also calling setRotation(1).
https://github.com/adafruit/Adafruit-PC ... cdtest.ino
This is an example sketch for our Monochrome Nokia 5110 LCD Displays
  Pick one up today in the adafruit shop!
  ------> http://www.adafruit.com/products/338
These displays use SPI to communicate, 4 or 5 pins are required to
interface
products from Adafruit!
Written by Limor Fried/Ladyada  for Adafruit Industries.
BSD license, check license.txt for more information
All text above, and the splash screen must be included in any redistribution
#include <SPI.h>
// Software SPI (slower updates, more flexible pin options):
// pin 7 - Serial clock out (SCLK)
// pin 6 - Serial data out (DIN)
// pin 5 - Data/Command select (D/C)
// pin 4 - LCD chip select (CS)
// pin 3 - LCD reset (RST)
Adafruit_PCD8544 display = Adafruit_PCD8544(7, 6, 5, 4, 3);
// Hardware SPI (faster, but must use certain hardware pins):
// SCK is LCD serial clock (SCLK) - this is pin 13 on Arduino Uno
// MOSI is LCD DIN - this is pin 11 on an Arduino Uno
// Adafruit_PCD8544 display = Adafruit_PCD8544(5, 4, 3);
// Note with hardware SPI MISO and SS pins aren't used but will still be read
// and written to during SPI transfer.  Be careful sharing these pins!
#define NUMFLAKES 10
#define XPOS 0
#define YPOS 1
#define DELTAY 2
#define LOGO16_GLCD_HEIGHT 16
#define LOGO16_GLCD_WIDTH  16
static const unsigned char PROGMEM logo16_glcd_bmp[] =
{ 0B00000000, 0B11000000,
  0B00000001, 0B11000000,
  0B00000011, 0B11100000,
  0B11110011, 0B11100000,
  0B11111110, 0B11111000,
  0B01111110, 0B11111111,
  0B00110011, 0B10011111,
  0B00011111, 0B11111100,
  0B00001101, 0B01110000,
  0B00011011, 0B10100000,
  0B00111111, 0B11100000,
  0B00111111, 0B11110000,
  0B01111100, 0B11110000,
  0B01110000, 0B01110000,
  0B00000000, 0B00110000 };
void testdrawbitmap(const uint8_t *bitmap, uint8_t w, uint8_t h) {
  uint8_t icons[NUMFLAKES][3];
  randomSeed(666);     // whatever seed
  // initialize
  for (uint8_t f=0; f< NUMFLAKES; f++) {
    icons[f][XPOS] = random(display.width());
    icons[f][YPOS] = 0;
    icons[f][DELTAY] = random(5) + 1;
    Serial.print("x: ");
    Serial.print(icons[f][XPOS], DEC);
    Serial.print(" y: ");
    Serial.print(icons[f][YPOS], DEC);
    Serial.print(" dy: ");
    Serial.println(icons[f][DELTAY], DEC);
  while (1) {
    // draw each icon
      display.drawBitmap(icons[f][XPOS], icons[f][YPOS], bitmap, w, h, BLACK);
    display.display();
    delay(200);
    while(Serial.available()) {
        switch (Serial.read()) {
          case 'w':display.setContrast(display.getContrast() + 1);
                   break;
          case 's':if(display.getContrast()) display.setContrast(display.getContrast() - 1);
                     break;
          case 'e':display.setBias(display.getBias() + 1);
                   break;
          case 'd':if(display.getBias()) display.setBias(display.getBias() - 1);
                   break;
          case 'R':display.setReinitInterval(10);
                   break;
          case 'r':display.initDisplay();
                   display.setReinitInterval(0);
                   break;
    Serial.print("contrast (w/s): 0x");
    Serial.print(display.getContrast(), HEX);
    Serial.print("   bias (e/d): 0x");
    Serial.print(display.getBias(), HEX);
    Serial.print("   reinitialize display (r/R): 0x");
    Serial.print(display.getReinitInterval(), HEX);
    Serial.print("   \r");
    // then erase it + move it
      display.drawBitmap(icons[f][XPOS], icons[f][YPOS],  logo16_glcd_bmp, w, h, WHITE);
      // move it
      icons[f][YPOS] += icons[f][DELTAY];
      // if its gone, reinit
      if (icons[f][YPOS] > display.height()) {
	icons[f][YPOS] = 0;
void testdrawchar(void) {
  display.setTextSize(1);
  for (uint8_t i=0; i < 168; i++) {
    if (i == '\n') continue;
    display.write(i);
    //if ((i > 0) && (i % 14 == 0))
      //display.println();
  display.display();
void testdrawcircle(void) {
  for (int16_t i=0; i<display.height(); i+=2) {
    display.drawCircle(display.width()/2, display.height()/2, i, BLACK);
    display.display();
void testfillrect(void) {
  uint8_t color = 1;
  for (int16_t i=0; i<display.height()/2; i+=3) {
    // alternate colors
    display.fillRect(i, i, display.width()-i*2, display.height()-i*2, color%2);
    display.display();
    color++;
void testdrawtriangle(void) {
  for (int16_t i=0; i<min(display.width(),display.height())/2; i+=5) {
    display.drawTriangle(display.width()/2, display.height()/2-i,
                     display.width()/2-i, display.height()/2+i,
                     display.width()/2+i, display.height()/2+i, BLACK);
    display.display();
void testfilltriangle(void) {
  uint8_t color = BLACK;
  for (int16_t i=min(display.width(),display.height())/2; i>0; i-=5) {
    display.fillTriangle(display.width()/2, display.height()/2-i,
                     display.width()/2+i, display.height()/2+i, color);
    if (color == WHITE) color = BLACK;
    else color = WHITE;
    display.display();
void testdrawroundrect(void) {
  for (int16_t i=0; i<display.height()/2-2; i+=2) {
    display.drawRoundRect(i, i, display.width()-2*i, display.height()-2*i, display.height()/4, BLACK);
    display.display();
void testfillroundrect(void) {
    display.fillRoundRect(i, i, display.width()-2*i, display.height()-2*i, display.height()/4, color);
    else color = WHITE;
    display.display();
void testdrawrect(void) {
  for (int16_t i=0; i<display.height()/2; i+=2) {
    display.drawRect(i, i, display.width()-2*i, display.height()-2*i, BLACK);
    display.display();
void testdrawline() {
  for (int16_t i=0; i<display.width(); i+=4) {
    display.drawLine(0, 0, i, display.height()-1, BLACK);
    display.display();
  for (int16_t i=0; i<display.height(); i+=4) {
    display.drawLine(0, 0, display.width()-1, i, BLACK);
    display.display();
  delay(250);
    display.drawLine(0, display.height()-1, i, 0, BLACK);
    display.display();
  for (int8_t i=display.height()-1; i>=0; i-=4) {
    display.drawLine(0, display.height()-1, display.width()-1, i, BLACK);
    display.display();
  delay(250);
  for (int16_t i=display.width()-1; i>=0; i-=4) {
    display.drawLine(display.width()-1, display.height()-1, i, 0, BLACK);
    display.display();
  for (int16_t i=display.height()-1; i>=0; i-=4) {
    display.drawLine(display.width()-1, display.height()-1, 0, i, BLACK);
    display.display();
  delay(250);
    display.drawLine(display.width()-1, 0, 0, i, BLACK);
    display.display();
    display.drawLine(display.width()-1, 0, i, display.height()-1, BLACK);
    display.display();
  delay(250);
void setup()   {
  Serial.begin(9600);
Serial.println("PCD test");
  display.begin();
  // init done
  // you can change the contrast around to adapt the display
  // for the best viewing!
  display.setContrast(75);
  display.display(); // show splashscreen
  delay(2000);
  display.clearDisplay();   // clears the screen and buffer
  // draw a single pixel
  display.drawPixel(10, 10, BLACK);
  display.display();
  delay(2000);
  // draw many lines
  testdrawline();
  display.display();
  delay(2000);
  // draw rectangles
  testdrawrect();
  display.display();
  delay(2000);
  // draw multiple rectangles
  testfillrect();
  display.display();
  delay(2000);
  // draw mulitple circles
  testdrawcircle();
  display.display();
  delay(2000);
  // draw a circle, 10 pixel radius
  display.fillCircle(display.width()/2, display.height()/2, 10, BLACK);
  display.display();
  delay(2000);
  testdrawroundrect();
  delay(2000);
  testfillroundrect();
  delay(2000);
  testdrawtriangle();
  delay(2000);
  testfilltriangle();
  delay(2000);
  // draw the first ~12 characters in the font
  testdrawchar();
  display.display();
  delay(2000);
  // text display tests
  display.println("Hello, world!");
  display.setTextColor(WHITE, BLACK); // 'inverted' text
  display.println(3.141592);
  display.print("0x"); display.println(0xDEADBEEF, HEX);
  display.display();
  delay(2000);
  // rotation example
  display.setRotation(1);  // rotate 90 degrees counter clockwise, can also use values of 2 and 3 to go further.
  display.println("Rotation");
  display.println("Example!");
  display.display();
  delay(2000);
  // revert back to no rotation
  display.setRotation(0);
  // miniature bitmap display
  display.drawBitmap(30, 16,  logo16_glcd_bmp, 16, 16, 1);
  display.display();
  // invert the display
  display.invertDisplay(true);
  delay(1000);
  display.invertDisplay(false);
  delay(1000);
  // draw a bitmap icon and 'animate' movement
  testdrawbitmap(logo16_glcd_bmp, LOGO16_GLCD_WIDTH, LOGO16_GLCD_HEIGHT);
Return to “Arduino”
