Use digitalWrite() and analogWrite() on same pin
PhilippCaspari
Post by PhilippCaspari »
Hey folks,
I have old code that I previously used on an Arduino Nano succesfully. Now I wanted to transition to an "Adafruit Feather nRF52840 express", but the board does not execute the following commands, like the Nano did. Here is the code:
#include <Adafruit_TinyUSB.h>
  pinMode(2, OUTPUT);
  digitalWrite(2, HIGH);
  delay(5000);
  Serial.println("Ontime over, now Dim");
  analogWrite(2, 64);
  delay(2500);
  Serial.println("Dimtime over, now ON");
I check the code with an LED on the output pin. The pin stays always in the same state of the first command, but does not change with the command. I seems like I have to decide, if I want to use an output pin only for PWM Signals, or only for HIGH and LOW pin states. Changing between analog and digital output does not work like on arduino, why is that the case?
dastels
Re: Use digitalWrite() and analogWrite() on same pin
Post by dastels »
Well, it's a completely different MCU with completely different pin management circuitry.
Analog writing the value for 100% PWM duty cycle (usually 255) will do what you're trying to do by digital writing HIGH.
PhilippCaspari
Thank you for your quick reply Dave :) So there is no possibility to switcht between digital output and analog output on a pin, once one of these methods is previously used on a pin?
Return to “Arduino”
