Using different MIDI over USB libraries my code seems to fail on reading the neokey.
Below the code of a standard example that works without the seesaw library and NeoKey stuff..
Adding the library is OK but as soon as I add a "neokey.read()" my code stops.
The QT Py with Adafruit NeoKey 1x4 QT I2C Breakout works OK with other code (no MIDI).
Lines I added are tagged "// ADDED FOR NeoKey TEST"
Any tips are welcome :-)
The code:
products from Adafruit!
MIT license, check LICENSE for more information
Copyright (c) 2019 Ha Thach for Adafruit Industries
All text above, and the splash screen below must be included in
any redistribution
/* This sketch is enumerated as USB MIDI device.
* Following library is required
* - MIDI Library by Forty Seven Effects
* https://github.com/FortySevenEffects/arduino_midi_library
#include <Arduino.h>
#include <Adafruit_TinyUSB.h>
#include <MIDI.h>
#include <Adafruit_NeoKey_1x4.h> // ADDED FOR NeoKey TEST
#include <seesaw_neopixel.h> // ADDED FOR NeoKey TEST
Adafruit_NeoKey_1x4 neokey; // ADDED FOR NeoKey TEST
// USB MIDI object
Adafruit_USBD_MIDI usb_midi;
// Create a new instance of the Arduino MIDI Library,
// and attach usb_midi as the transport.
MIDI_CREATE_INSTANCE(Adafruit_USBD_MIDI, usb_midi, MIDI);
// Variable that holds the current position in the sequence.
uint32_t position = 0;
// Store example melody as an array of note values
byte note_sequence[] = {
74,78,81,86,90,93,98,102,57,61,66,69,73,78,81,85,88,92,97,100,97,92,88,85,81,78,
74,69,66,62,57,62,66,69,74,78,81,86,90,93,97,102,97,93,90,85,81,78,73,68,64,61,
56,61,64,68,74,78,81,86,90,93,98,102
void setup()
#if defined(ARDUINO_ARCH_MBED) && defined(ARDUINO_ARCH_RP2040)
// Manual begin() is required on core without built-in support for TinyUSB such as mbed rp2040
TinyUSB_Device_Init(0);
#endif
pinMode(LED_BUILTIN, OUTPUT);
usb_midi.setStringDescriptor("TinyUSB MIDI");
// Initialize MIDI, and listen to all MIDI channels
// This will also call usb_midi's begin()
MIDI.begin(MIDI_CHANNEL_OMNI);
// Attach the handleNoteOn function to the MIDI Library. It will
// be called whenever the Bluefruit receives MIDI Note On messages.
MIDI.setHandleNoteOn(handleNoteOn);
// Do the same for MIDI Note Off messages.
MIDI.setHandleNoteOff(handleNoteOff);
Serial.begin(115200);
// wait until device mounted
while( !TinyUSBDevice.mounted() ) delay(1);
void loop()
/* If the line below is active (just reading the neokey 1x4) my code is not executed */
// uint8_t buttons = neokey.read(); // ADDED FOR NeoKey TEST
static uint32_t start_ms = 0;
if ( millis() - start_ms > 266 )
start_ms += 266;
// Setup variables for the current and previous
// positions in the note sequence.
int previous = position - 1;
// If we currently are at position 0, set the
// previous position to the last note in the sequence.
if (previous < 0) {
previous = sizeof(note_sequence) - 1;
// Send Note On for current position at full velocity (127) on channel 1.
MIDI.sendNoteOn(note_sequence[position], 127, 1);
// Send Note Off for previous note.
MIDI.sendNoteOff(note_sequence[previous], 0, 1);
// Increment position
position++;
// If we are at the end of the sequence, start over.
if (position >= sizeof(note_sequence)) {
position = 0;
// read any new MIDI messages
MIDI.read();
void handleNoteOn(byte channel, byte pitch, byte velocity)
// Log when a note is pressed.
Serial.print("Note on: channel = ");
Serial.print(channel);
Serial.print(" pitch = ");
Serial.print(pitch);
Serial.print(" velocity = ");
Serial.println(velocity);
void handleNoteOff(byte channel, byte pitch, byte velocity)
// Log when a note is released.
Serial.print("Note off: channel = ");
