The MEGA2560_MCP4261_Bluetooth sketch need help please
oladam
Post by oladam »
The MEGA2560_MCP4261_Bluetooth sketch working well, with the line128 comment out; does't work as long as remove the '//' , why?
The code and diagram attached, I used MEGA and did relative modify with pins, and checked the MCP4261 and motors separately and they work well.
Thanks for help.
Adam
#include <SPI.h>
//MCP cinfigrition
const int slaveSelectPin = 53; //WAS 10 on Arduino uno.
const int shutdownPin = 49; // was 7 on uno.
const int wiper0writeAddr = B00000000;  //these addresses can be found in your chip's datasheet
const int wiper1writeAddr = B00010000;
uint8_t receivedValue_x = 0;
uint8_t receivedValue_y = 0;
#define enA 8
#define in1 4
#define in2 5
#define in3 6
#define in4 7
#define enB 9
int xAxis = 140, yAxis = 140;
int motorSpeedA = 0;
int motorSpeedB = 0;
  pinMode(enA, OUTPUT);
  pinMode(enB, OUTPUT);
  pinMode(in1, OUTPUT);
  pinMode(in2, OUTPUT);
  pinMode(in3, OUTPUT);
  pinMode(in4, OUTPUT);
  pinMode (slaveSelectPin, OUTPUT);
  pinMode (shutdownPin, OUTPUT);
  Serial1.begin(9600); // Default communication rate of the Bluetooth module
  delay(500);
  // Default value - no movement when the Joystick stays in the center
  //xAxis = 140;
  //yAxis = 140;
  // Read the incoming data from the Smartphone Android App
  while (Serial1.available() >= 2) {
    xAxis = Serial1.read();
    delay(10);
    yAxis = Serial1.read();
    Serial.print(xAxis);
    Serial.print(",");
    Serial.println(yAxis);
  delay(10);
  // Makes sure we receive corrent values
  if (xAxis > 130 && xAxis < 150 && yAxis > 130 && yAxis < 150)
    Stop();
  if (yAxis > 130 && yAxis < 150) {
    if (xAxis < 130) {
      turnRight();
      motorSpeedA = map(xAxis, 130, 60, 0, 255);
      motorSpeedB = map(xAxis, 130, 60, 0, 255);
    if (xAxis > 150) {
      turnLeft();
      motorSpeedA = map(xAxis, 150, 220, 0, 255);
      motorSpeedB = map(xAxis, 150, 220, 0, 255);
  } else {
    if (xAxis > 130 && xAxis < 150) {
      if (yAxis < 130) {
        forword();
      if (yAxis > 150) {
        backword();
      if (yAxis < 130) {
        motorSpeedA = map(yAxis, 130, 60, 0, 255);
        motorSpeedB = map(yAxis, 130, 60, 0, 255);
      if (yAxis > 150) {
        motorSpeedA = map(yAxis, 150, 220, 0, 255);
        motorSpeedB = map(yAxis, 150, 220, 0, 255);
    } else {
      if (yAxis < 130) {
        forword();
      if (yAxis > 150) {
        backword();
      if (xAxis < 130) {
        motorSpeedA = map(xAxis, 130, 60, 255, 50);
        motorSpeedB = 255;
      if (xAxis > 150) {
        motorSpeedA = 255;
        motorSpeedB = map(xAxis, 150, 220, 255, 50);
  //Serial.print(motorSpeedA);
  //Serial.print(",");
  //Serial.println(motorSpeedA);
  analogWrite(enA, motorSpeedA); // Send PWM signal to motor A
  analogWrite(enB, motorSpeedB); // Send PWM signal to motor B
  // mcpDrive();
  Serial.print("motorSpeedA122=");
void mcpDrive ()
  digitalPotWrite(wiper0writeAddr, motorSpeedA); // Send PWM signal to motor A
  digitalPotWrite(wiper1writeAddr, motorSpeedB); // Send PWM signal to motor B
void digitalPotWrite(int address, int value) {
  digitalWrite(slaveSelectPin, LOW);
  delay(5);
  /// digitalWrite(shutdownPin, HIGH); //Turn off shutdown THIS MAKE WRITEABLE OR DISABLE THIS CAN'T WRITE
  //  send in the address and value via SPI:
  SPI.transfer(address);
  SPI.transfer(value);
  digitalWrite(slaveSelectPin, HIGH);
  delay(5);
void forword() {
  Serial.println("forword");
  digitalWrite(in1, HIGH);
  digitalWrite(in2, LOW);
  digitalWrite(in3, HIGH);
  digitalWrite(in4, LOW);
void backword() {
  Serial.println("backword");
  digitalWrite(in1, LOW);
  digitalWrite(in2, HIGH);
  digitalWrite(in3, LOW);
  digitalWrite(in4, HIGH);
void turnRight() {
  Serial.println("turnRight");
void turnLeft() {
  Serial.println("turnLeft");
void Stop() {
  Serial.println("stop");
[img]
https://ibb.co/pXvvS5s
[/img]
Return to “Arduino”
