The MEGA2560_MCP4261_Bluetooth sketch working well, with the line128 comment out; does't work as long as remove the '//' , why?
The code and diagram attached, I used MEGA and did relative modify with pins, and checked the MCP4261 and motors separately and they work well.
Thanks for help.
Adam
#include <SPI.h>
//MCP cinfigrition
const int slaveSelectPin = 53; //WAS 10 on Arduino uno.
const int shutdownPin = 49; // was 7 on uno.
const int wiper0writeAddr = B00000000; //these addresses can be found in your chip's datasheet
const int wiper1writeAddr = B00010000;
uint8_t receivedValue_x = 0;
uint8_t receivedValue_y = 0;
#define enA 8
#define in1 4
#define in2 5
#define in3 6
#define in4 7
#define enB 9
int xAxis = 140, yAxis = 140;
int motorSpeedA = 0;
int motorSpeedB = 0;
pinMode(enA, OUTPUT);
pinMode(enB, OUTPUT);
pinMode(in1, OUTPUT);
pinMode(in2, OUTPUT);
pinMode(in3, OUTPUT);
pinMode(in4, OUTPUT);
pinMode (slaveSelectPin, OUTPUT);
pinMode (shutdownPin, OUTPUT);
Serial.begin(9600);
Serial1.begin(9600); // Default communication rate of the Bluetooth module
delay(500);
// Default value - no movement when the Joystick stays in the center
//xAxis = 140;
//yAxis = 140;
// Read the incoming data from the Smartphone Android App
while (Serial1.available() >= 2) {
xAxis = Serial1.read();
delay(10);
yAxis = Serial1.read();
Serial.print(xAxis);
Serial.print(",");
Serial.println(yAxis);
delay(10);
// Makes sure we receive corrent values
if (xAxis > 130 && xAxis < 150 && yAxis > 130 && yAxis < 150)
Stop();
if (yAxis > 130 && yAxis < 150) {
if (xAxis < 130) {
turnRight();
motorSpeedA = map(xAxis, 130, 60, 0, 255);
motorSpeedB = map(xAxis, 130, 60, 0, 255);
if (xAxis > 150) {
turnLeft();
motorSpeedA = map(xAxis, 150, 220, 0, 255);
motorSpeedB = map(xAxis, 150, 220, 0, 255);
} else {
if (xAxis > 130 && xAxis < 150) {
if (yAxis < 130) {
forword();
if (yAxis > 150) {
backword();
if (yAxis < 130) {
motorSpeedA = map(yAxis, 130, 60, 0, 255);
motorSpeedB = map(yAxis, 130, 60, 0, 255);
if (yAxis > 150) {
motorSpeedA = map(yAxis, 150, 220, 0, 255);
motorSpeedB = map(yAxis, 150, 220, 0, 255);
} else {
if (yAxis < 130) {
forword();
if (yAxis > 150) {
backword();
if (xAxis < 130) {
motorSpeedA = map(xAxis, 130, 60, 255, 50);
motorSpeedB = 255;
if (xAxis > 150) {
motorSpeedA = 255;
motorSpeedB = map(xAxis, 150, 220, 255, 50);
//Serial.print(motorSpeedA);
//Serial.print(",");
//Serial.println(motorSpeedA);
analogWrite(enA, motorSpeedA); // Send PWM signal to motor A
analogWrite(enB, motorSpeedB); // Send PWM signal to motor B
// mcpDrive();
Serial.print("motorSpeedA122=");
void mcpDrive ()
digitalPotWrite(wiper0writeAddr, motorSpeedA); // Send PWM signal to motor A
digitalPotWrite(wiper1writeAddr, motorSpeedB); // Send PWM signal to motor B
void digitalPotWrite(int address, int value) {
digitalWrite(slaveSelectPin, LOW);
delay(5);
/// digitalWrite(shutdownPin, HIGH); //Turn off shutdown THIS MAKE WRITEABLE OR DISABLE THIS CAN'T WRITE
// send in the address and value via SPI:
SPI.transfer(address);
SPI.transfer(value);
digitalWrite(slaveSelectPin, HIGH);
delay(5);
void forword() {
Serial.println("forword");
digitalWrite(in1, HIGH);
digitalWrite(in2, LOW);
digitalWrite(in3, HIGH);
digitalWrite(in4, LOW);
void backword() {
Serial.println("backword");
digitalWrite(in1, LOW);
digitalWrite(in2, HIGH);
digitalWrite(in3, LOW);
digitalWrite(in4, HIGH);
void turnRight() {
Serial.println("turnRight");
void turnLeft() {
Serial.println("turnLeft");
void Stop() {
Serial.println("stop");
https://ibb.co/pXvvS5s
[/img]
