Pico Feather w/ seesaw encoder
me_is_pete
Post by me_is_pete »
I can see the seesaw rotary encoder module (via a stemma connector) just fine from circuit python but not when using the Arduino interface. It seems that I need to tell the seesaw library to look for Wire1 or change the SDA/SCL pins assignments?
Has anybody done this?
I tired adding a few lines to the basic_encode in examples:
#include <Wire.h>
#include "Adafruit_seesaw.h"
#include <seesaw_neopixel.h>
Adafruit_seesaw ss(&Wire1);
Never seems to find the seesaw device.
Works fine on circuit python and a M4 feather express - what am I missing?
adafruit_support_carter
Re: Pico Feather w/ seesaw encoder
Can you get the board to show up in an I2C scan?
https://learn.adafruit.com/scanning-i2c ... es/arduino
me_is_pete
Thank you!
When I define WIRE to Wire1 I see it (thanks)
18:17:42.509 -> Scanning...
18:17:42.550 -> I2C device found at address 0x36 !
18:17:42.550 -> done
I have a rp2040 feather w/ the encoder connected to the stemma port (nothing else).
I followed the instructions to get the board and libraries through the Arduino interface and am just using the the basic_encoder example.
There isn't an obvious way to define the Wire channel in this simple example.
I thought that it would be when the object is defined?
#define SEESAW_ADDR 0x36
Adafruit_seesaw ss;
Thanks for your guidance!
OK, at least we know it can be seen. So we know basic connections are OK.
What you showed in your first post *should* be how to specify Wire1 as the I2C bus to use:
When you run the encoder_basic example,
https://github.com/adafruit/Adafruit_Se ... _basic.ino
modified with the line of code above to use Wire1, what gets printed in the Serial Monitor?
me_is_pete
I got "Couldn't find seesaw on default address"
I modified the seesaw constructor (Adafruit_seesaw.cpp) from:
Adafruit_seesaw::Adafruit_seesaw(TwoWire *i2c_bus) {
   if (i2c_bus == NULL) {
     _i2cbus = &Wire;
   } else {
     _i2cbus = i2c_bus;
to:
#if defined(ARDUINO_ADAFRUIT_FEATHER_RP2040)
	  _i2cbus = &Wire1;
#else
    _i2cbus = &Wire;
#endif
  } else {
    _i2cbus = i2c_bus;
That works!
Does that means that Wire1 is still NULL when it get's passed to the constructor? So _i2cbus goes back to Wire?
I'm happy w/ this but is there a more appropriate way?
Thanks again!
That is weird. Just to be sure, you're still creating the seesaw object like this?
That should end up being not NULL and using Wire1.
Return to “Arduino”
