I can see the seesaw rotary encoder module (via a stemma connector) just fine from circuit python but not when using the Arduino interface. It seems that I need to tell the seesaw library to look for Wire1 or change the SDA/SCL pins assignments?
Has anybody done this?
I tired adding a few lines to the basic_encode in examples:
#include <Wire.h>
#include "Adafruit_seesaw.h"
#include <seesaw_neopixel.h>
Adafruit_seesaw ss(&Wire1);
Never seems to find the seesaw device.
Works fine on circuit python and a M4 feather express - what am I missing?
Pico Feather w/ seesaw encoder
- adafruit_support_carter
Re: Pico Feather w/ seesaw encoder
Can you get the board to show up in an I2C scan?
https://learn.adafruit.com/scanning-i2c ... es/arduino
- me_is_pete
Thank you!
When I define WIRE to Wire1 I see it (thanks)
18:17:42.509 -> Scanning...
18:17:42.550 -> I2C device found at address 0x36 !
18:17:42.550 -> done
I have a rp2040 feather w/ the encoder connected to the stemma port (nothing else).
I followed the instructions to get the board and libraries through the Arduino interface and am just using the the basic_encoder example.
There isn't an obvious way to define the Wire channel in this simple example.
I thought that it would be when the object is defined?
#define SEESAW_ADDR 0x36
Adafruit_seesaw ss;
Thanks for your guidance!
Adafruit_seesaw ss;
OK, at least we know it can be seen. So we know basic connections are OK.
What you showed in your first post *should* be how to specify Wire1 as the I2C bus to use:
When you run the encoder_basic example,
https://github.com/adafruit/Adafruit_Se ... _basic.ino
modified with the line of code above to use Wire1, what gets printed in the Serial Monitor?
- me_is_pete
I got "Couldn't find seesaw on default address"
I modified the seesaw constructor (Adafruit_seesaw.cpp) from:
to:
That works!
Does that means that Wire1 is still NULL when it get's passed to the constructor? So _i2cbus goes back to Wire?
I'm happy w/ this but is there a more appropriate way?
Thanks again!
Adafruit_seesaw::Adafruit_seesaw(TwoWire *i2c_bus) {
if (i2c_bus == NULL) {
_i2cbus = &Wire;
} else {
_i2cbus = i2c_bus;
#if defined(ARDUINO_ADAFRUIT_FEATHER_RP2040)
_i2cbus = &Wire1;
#else
_i2cbus = &Wire;
#endif
} else {
_i2cbus = i2c_bus;
Thanks again!
That is weird. Just to be sure, you're still creating the seesaw object like this?
That should end up being not NULL and using Wire1.
