BNO055 not calibrating Accel=0
Juaxs
Post by Juaxs »
recently y got my BNO055 imu and im using the Adafruits BNO055 library to get the calibration information and im getting a problem with the accelerometer calibration value.
X: 63.3750	Y: -3.3750	Z: 3.6875	Sys:3 G:3 A:0 M:3
The system is located on a flat surface at the beginning of the calibration process but the A value is always at zero, i don't know why, and that's the reason i cannot get the exact calibration to set the acc offsets.
Im running the restore_offsets.ino example included on the library.
Thank you.
sj_remington
Re: BNO055 not calibrating Accel=0
Post by sj_remington »
See this page for instructions on how to calibrate the BNO055. The embedded video is helpful.
https://learn.adafruit.com/adafruit-bno ... alibration
Juaxs
Post by Juaxs »
I’m getting the problem following that page.
Juaxs
Post by Juaxs »
O have to mention that I’m using the 0x29 address using the 3.3v pin on ADR.
Juaxs
Post by Juaxs »
How can I update the sensor using arduino?
jps2000
Post by jps2000 »
It is not possible that SYS = 3 and ACC = 0.
So I expect something wrong in the code or in the communication.
Return to “Arduino”
