Need Help with RTC on data logger
tsans99
Post by tsans99 »
I'm trying to use the Data Logger with an Arduino Uno to write data to an SD card along with the date.
I wrote a simple sketch to test out the code and I'm not all that good at it and I get an error as seen in the attached file. I also am including the entire sketch and would appreciate any help. I don't know if there are any other errors beyond what shown so if anyone sees any please let me know.
Tom
//Initialise LCD display
#include <SPI.h>        // Include SPI library (needed for the SD card)
#include <SD.h>         // Include SD library
#include "RTClib.h"     // Include RTC Library
File myFile;
//Setup Variables
  int data =1;
  float DateTime;
  int chipSelect = 10;  // chipselect pin for the SD card reader
  void setup()
  Serial.begin(9600);  //Start the serial connection
// Check for SD card initialization
  while (!Serial) {; // wait for serial port to connect. Needed for native USB port only
  Serial.print("Initializing SD card...");
  if (!SD.begin()) {
    Serial.println("initialization failed!");
    while (1);
  Serial.println("initialization done.");
void loop()
  Serial.print(now.year(), DEC);
  Serial.print('/');
  Serial.print(now.month(), DEC);
  Serial.print('/');
  Serial.print(now.day(), DEC);
  Serial.print(" (");
  Serial.print(") ");
  Serial.print(now.hour(), DEC);
  Serial.print(':');
  Serial.print(now.minute(), DEC);
  Serial.print(':');
  Serial.print(now.second(), DEC);
  Serial.print(data);
  // SD Card Write
//open the file.
myFile = SD.open("RTCtest.txt", FILE_WRITE);
//write to file
if (myFile)
Serial.print("Writing to RTCtest.txt...");
  myFile.print(now.year(), DEC);
  myFile..print('/');
  myFile..print(now.month(), DEC);
  myFile..print('/');
  myFile..print(now.day(), DEC);
  myFile.l.print(" (");
  myFile..print(") ");
  myFile..print(now.hour(), DEC);
  myFile..print(':');
  myFile..print(now.minute(), DEC);
  myFile..print(':');
  myFile..print(now.second(), DEC);
  myFile.print("Data  ,");
  myFile.println(data);
//close the file
  myFile.close();
 Serial.println("done.");
else
// if the file didn't open, print an error:
Serial.println("error opening Weather.txt file");
Last edited by adafruit_support_bill on Tue Nov 30, 2021 3:07 pm, edited 1 time in total.
Reason: Please use [code] tags when posting code to the forums.
Re: Need Help with RTC on data logger
As the error message says, you can't declare your loop() function inside of your setup function.
Your setup function has more '{' than '}' so as far as the compiler is concerned, it never ends. It is a lot easier to catch problems like these if you use consistent indenting in your code:
	void setup()
			if (!SD.begin())
				while (1);
		///**** missing '}' here ***
		void loop()
rpiloverbd
Post by rpiloverbd »
This error appears when you do not close a second bracket. In your setup function, I can see that no. of '{' and No. of '}' s are not equal. Please correct it. Hopefully your code will compile.
dastels
Post by dastels »
The problem is that here is an extra opening brace:
while (!Serial) {;
dastels
Post by dastels »
Note that in the Arduino editor you can press Control/Command-T (also Autoformat in the tools menu) to format your code (well, indent it) consistently.
tsans99
Post by tsans99 »
I do appreciate all the help and it should be obvious I'm VERY new to this. I did some online studying but it wasn't enough to get the things I want done so I'm here for all the help I can get.
I fixed the bracket problem and it's something I should have seen but missed and used the Auto Format tool (who knew). Now the next problem seems to be that 'rtc' and 'now' were not declared in this scope. I've attached the new sketch and if anyone can take a quick look at it and see any other errors it will stop me from having to ask for help again.
Thanks to all,
Tom
  TAS Design 11-28-21
File myFile;
//Setup Variables
//int data =1;
// float DateTime;
//int chipSelect = 10;  // chipselect pin for the SD card reader
//int now
void setup()
  while (!Serial) ; // wait for serial port to connect. Needed for native USB port only
    if (!SD.begin())
    while (1);
void loop()
  DateTime now = rtc.now();
  Serial.print('/');
  Serial.print('/');
  Serial.print(" (");
  Serial.print(") ");
  Serial.print(':');
  Serial.print(':');
  Serial.print(data);
  // SD Card Write
  //open the file.
  //write to file
  if (myFile)
    myFile.print('/');
    myFile.print(now.month(), DEC);
    myFile.print('/');
    myFile.print(now.day(), DEC);
    myFile.print(" (");
    myFile.print(") ");
    myFile.print(now.hour(), DEC);
    myFile.print(':');
    myFile.print(now.minute(), DEC);
    myFile.print(':');
    myFile.print(now.second(), DEC);
    //close the file
    myFile.close();
  else
    Serial.println("error opening RTCtest.txt file");
[The extension ino has been deactivated and can no longer be displayed.]
Last edited by adafruit_support_bill on Wed Dec 01, 2021 11:51 am, edited 1 time in total.
Reason: Added code in-line. Please use [code] tags when posting code to the forums.
dastels
Post by dastels »
Yes, that's because you haven't declared them.
I see the declaration (and assignment) of the variable now in the loop() function. I'm guessing that the now that's it's complaining about is the now function you are calling on rtc... guessing because you didn't include the compiler output (which is pretty much required when asking about compiler errors). rtc isn't declated anywhere. You will need to do that near the top of the file (after the includes). The exact declaration will depend on the RTC that you have, but will be something like
RTC_DS3231 rtc;
Unrelated, but the
while( 1);
should, I believe, be inside the
if (!SD.begin())
loop. You also don't need the brace delineated block following
while (!Serial) ;
tsans99
Post by tsans99 »
I made the corrections you suggested and added RTC_PCF8523 rtc; so now I get all the way through Verify/Compile with no errors. I'll try to run and hopefully it's successful.
Tom
tsans99
Post by tsans99 »
Well, no errors but it doesn't run.
It seems to hang-up writing the first line to the serial monitor - see screen shot - and never completes the write. Not unexpectedly, the file is not created on the SD card.
Any Ideas?
Tom
Screen Shot.jpg (35.67 KiB) Viewed 404 times
Please post your modified code. If your setup still has this, then the behavior you describe would be expected.
    if (!SD.begin())
    while (1);
tsans99
Post by tsans99 »
Latest Code
  TAS Design 11-28-21
File myFile;
RTC_PCF8523 rtc;
//Setup Variables
int data =1;
void setup()
    if (!SD.begin(10))
        while (1);
void loop()
  Serial.print('/');
  Serial.print('/');
  Serial.print(" (");
  Serial.print(") ");
  Serial.print(':');
  Serial.print(':');
  Serial.print(data);
  // SD Card Write
  //open the file.
  //write to file
  if (myFile)
    myFile.print('/');
    myFile.print('/');
    myFile.print(" (");
    myFile.print(") ");
    myFile.print(':');
    myFile.print(':');
    //close the file
    myFile.close();
  else
Last edited by adafruit_support_bill on Wed Dec 01, 2021 3:34 pm, edited 1 time in total.
Please use
 tags when posting code to the forums so that people don't have to download your files in order to help.  Just press on the [code] button and paste your code between the [code] tags.
You code is probably hanging because you are not calling rtc.begin() to initialize the PCF8523.  See the example code in the library:
https://github.com/adafruit/RTClib/blob/master/examples/pcf8523/pcf8523.ino
dastels
Post by dastels »
As Bill said, you're missing the initializatio9n of the RTC via a begin call. Almost all (and possibly all) Adafruit sensor libraries use a begin method for initialization. Something to keep in mind.
Please have a look at the library examples, specifically https://github.com/adafruit/RTClib/blob ... ds3231.ino.
Reading the tutorial guides would avoid a lot of erros and time spent debugging as well: https://learn.adafruit.com/adafruit-ds3 ... c-breakout.
Return to “Arduino”
