code error
Johnathan_hoang
code error
Post by Johnathan_hoang »
i have copied the code from the adafruit unibeam guide and also found a previous forum about changing the curly brackets to semicolons but i still am having issues with the code
  // put your setup code here, to run once:
  // put your main code here, to run repeatedly:
#include <avr/power.h>
#ifdef __AVR_ATtiny85__ // Trinket/Gemma:
 #define LEDPIN  1      //   NeoPixels connect here
 #define MODEPIN 0      //   Switch modes w/button between this pin & GND
 #define FIREPIN 2      //   'Fire' w/button between this pin & GND
#else                   // Arduino Uno & everything else:
 #define LEDPIN  6      //   NeoPixels connect here
 #define MODEPIN 4      //   Mode button between this & GND
 #define FIREPIN 5      //   Fire button between this & GND
#endif
// Partial color assignments for various ring states; HSV colorspace,
// not RGB.  Hue is always determined by the current mode, so these
// just include saturation and value (brightness).
#define IDLE_PEAK_SAT       255 // "Dim" rings
#define IDLE_PEAK_VALUE     130
#define IDLE_TROUGH_SAT     255
#define IDLE_TROUGH_VALUE    45
#define BRIGHT_PEAK_SAT      80 // Current "bright" ring
#define BRIGHT_PEAK_VALUE   230
#define BRIGHT_TROUGH_SAT   255
#define BRIGHT_TROUGH_VALUE 135
#define AIM_SAT               0 // Ramping up to fire...
#define AIM_PEAK_VALUE      140
#define AIM_TROUGH_VALUE    120
#define FIRE_SAT              0 // Firing
#define FIRE_VALUE          255
#define DEBOUNCE             10 // Counter limit for mode, fire buttons
// Okay, this is just terrible, don't try this at home.  I'd been curious
// if one could use the preprocessor, not runtime code, to sum values in
// a struct array.  Here, counting the number of pixels in a list of
// NeoPixel rings in order to declare the single Adafruit_NeoPixel strip
// length.  List can then change without editing the declaration every
// time; it follows automatically.  Short answer: yes, it can be done.
// Long answer: this is a hack and not well-behaved C syntax for anything,
// please don't use as a model for your own code, was just an experiment.
// List rings here -- index of first LED, number of LEDs, number of wave
// repetitions.  This is the order in which they're referenced in the
// ring[] array later, and doesn't need to match the order in which they're
// physically connected.  They should not overlap, nor should there be any
// gaps.  No code is generated here...all just preprocessor shenanigans.
#define RING_TABLE \
  ring(30, 16, 3)  \
  ring( 0, 24, 4)  \
  ring(24,  6, 2)  \
  // Don't remove this comment
// Preprocessor trick counts the total number of LEDs in the list.
// Adapted from supercat's code at stackoverflow.com/questions/3539549
#define ring(f,n,r) EN_##n}; enum {EN_SZ_##n=n,EN_TMP_##n=EN_##n+(n-1),
enum {EN_IDX=-1, RING_TABLE N_LEDS};
#undef  ring // After enumeration, same macro now inits array defaults:
#define ring(first,n,r) { first, n, r, {128,128,128}, 0, {0,0,0}, {{{0,0,0}, {0,0,0}}, {{0,0,0}, {0,0,0}}, {{0,0,0}, {0,0,0}}} },
// All so we can do this:
Adafruit_NeoPixel strip = Adafruit_NeoPixel(N_LEDS, LEDPIN);
// instead of ring[0].length + ring[1].length + ... + ring[2].length
// Each ring animates based on one or more full cycles of a triangle wave,
// which may be skewed toward a sawtooth wave.  RGB colors are interpolated
// between the peaks and troughs of the wave.
struct Ring {
  const uint8_t     firstLED; // Index of first pixel along full strand
  const uint8_t     nLEDs;    // Number of LEDs in ring
  uint8_t           reps;     // Number of wave cycles around ring
  uint8_t           peak[3];  // [to/from/current] sawtooth peak offset (0-255)
  volatile uint16_t phase;    // Offset angle (65536 = 360 degrees)
  volatile int16_t  spd[3];   // [to/from/current] phase increment per frame
  volatile uint8_t  color[3][2][3]; // [to/from/current][peak/trough][R,G,B]
} ring[] = {
  RING_TABLE // Macro above expands this into data for all rings
#define N_RINGS (sizeof(ring) / sizeof(ring[0]))
// Each of three animation modes has a distinct color and a rotation
// speed/direction for each of the rings.
// Clockwise direction is different on 16 pixel ring vs 24 (and the
// arrangement of 6 discrete NeoPixels).  On 16 pixel ring: + is clockwise,
// - is counterclockwise.  On 24 pixel ring (and our 6 pixel ring), - is
// clockwise, + is counterclockwise.
struct Mode {
  const int16_t hue;
  const int16_t speed[3];
} modeData[] = {
  1100, {  2500, -2000,  1500}, // Blue mode  (CW , CW , CCW)
   510, {  2500,  2000, -1500}, // Green mode (CW , CCW, CW )
    15, { -2500, -2000, -1500}, // Red mode   (CCW, CW , CW )
#define N_MODES (sizeof(modeData) / sizeof(modeData[0]))
extern const uint8_t gamma8[]; // Table at bottom of this file
uint8_t
  mode       = 0,
  brightRing = N_RINGS - 1;   // Counts through rings for pulsing effect
volatile uint8_t
  interpFrames  = 0,          // Duration of color/speed transition
  interpolating = 0;          // Current transition counter, 0=done
void setup() ;
#if defined(__AVR_ATtiny85__) && (F_CPU == 16000000L) // 16 MHz Trinket?
  clock_prescale_set(clock_div_1);
#endif
  strip.begin();
  strip.show(); // Initialize all pixels to 'off' ASAP
  pinMode(MODEPIN, INPUT_PULLUP);
  pinMode(FIREPIN, INPUT_PULLUP);
  // Configure "bootup" transition
  setRingsToIdleValues();
  startInterp(105); // ~3.5 second startup
  // Configure Timer/Counter 1 for 30-ish Hz interrupt
 #if (F_CPU == 16000000)                      // 16 MHz:
  TCCR1  = _BV(CS13) | _BV(CS12);             //  1:2048 prescale
 #else                                        // 8 MHz:
  TCCR1  = _BV(CS13) | _BV(CS11) | _BV(CS10); //  1:1024 prescale
 #endif
  GTCCR  = 0;                                 //  No PWM out
  TIMSK  = _BV(TOIE1);                        //  Overflow interrupt
#else                                         // Everything else:
  TCCR1A = _BV(WGM11) | _BV(WGM10);           //  Mode 15, no PWM out
  TCCR1B = _BV(WGM13) | _BV(WGM12) | _BV(CS11) | _BV(CS10); //  1:64 prescale
  OCR1A  =  F_CPU / 64 / 30;                  //  ~30 Hz cycle
  TIMSK1 = _BV(TOIE1);                        //  Overflow interrupt
#endif
  // Once the interrupt is enabled, animation (and transitions between
  // animation states) all occur automatically.  We just monitor the
  // 'interpolating' variable to indicate when the current transition is
  // done before issuing another.
  while(interpolating); // Wait for bootup transition to complete
// Don't return until both buttons are released and debounced
void waitForButtonRelease() ;
  for(uint8_t i=0;;) {
    if((digitalRead(MODEPIN) == LOW) || (digitalRead(FIREPIN) == LOW)) i=0;
    else if(++i >= DEBOUNCE) return;
// Set all rings to 'dim' colors for current mode
void setRingsToIdleValues() ;
  for(uint8_t r=0; r<N_RINGS; r++) {
    setTargetColor(r, modeData[mode].hue,
      IDLE_PEAK_SAT, IDLE_PEAK_VALUE, IDLE_TROUGH_SAT, IDLE_TROUGH_VALUE);
    setTargetSpeed(r, modeData[mode].speed[r]);
void nextMode() ;
  setRingsToIdleValues();                // Bright ring will fade off
  for(startInterp(10); interpolating; ); // ~1/3 sec transition
  if(++mode >= N_MODES) mode = 0;        // Advance/wrap mode counter
  setRingsToIdleValues();                // Set new colors/speeds
  brightRing = N_RINGS - 1;              // Start w/center after transition
  for(startInterp(45); interpolating; ); // ~1.5 sec. transition
  waitForButtonRelease();
void fire() ;
  uint8_t r;
  for(r=0; r<N_RINGS; r++) {             // All rings fade to 'aim' state...
      AIM_SAT, AIM_PEAK_VALUE, AIM_SAT, AIM_TROUGH_VALUE);
    setTargetSpeed(r, modeData[mode].speed[r] * 10);
  for(startInterp(105); interpolating; ); // 3.5 sec warmup transition
  for(startInterp( 40); interpolating; ); // 1.3 sec hold
  for(r=0; r<N_RINGS; r++) { // All rings fade to 'fire' state...
      FIRE_SAT, FIRE_VALUE, FIRE_SAT, FIRE_VALUE);
  for(startInterp(7); interpolating; );   // ~1/4 sec ramp up..."boom"
  setRingsToIdleValues();                 // Fade back to prior colors
  for(startInterp(120); interpolating; ); // ~4 sec cool-down
  brightRing = N_RINGS - 1;               // Resume @ center after firing
void loop() ;
  uint8_t pinState, priorPinState, debounceCounter, nextAction = 0;
  // For next transition...first, set bright ring back to idle color...
  setTargetColor(brightRing, modeData[mode].hue,
  if(++brightRing >= N_RINGS) brightRing = 0; // Next ring
  // ...then set new ring to bright state...
  setTargetColor(brightRing, modeData[mode].hue, BRIGHT_PEAK_SAT,
    BRIGHT_PEAK_VALUE, BRIGHT_TROUGH_SAT, BRIGHT_TROUGH_VALUE);
  startInterp(18); // Start pulse transition, about 2/3 sec
  // While the transition takes place, we can do other things, like
  // poll the buttons for mode change or fire events...
  priorPinState   = digitalRead(MODEPIN) + (digitalRead(FIREPIN) << 1);
  debounceCounter = 0;
  while(interpolating) { // Still transitioning...
    if(nextAction) continue; // Once action is decided, stop polling buttons
    pinState = digitalRead(MODEPIN) + (digitalRead(FIREPIN) << 1);
    if(pinState == priorPinState) {
      if(++debounceCounter >= DEBOUNCE) nextAction = pinState;
    } else {
      priorPinState   = pinState;
  // Downside is that mode/fire actions don't take place until the prior
  // transition ends (worst case, about 2/3 sec.), so this sometimes
  // requires a bit of button mashing.  I'd been working on making the
  // pulse transitions interruptible but ran out of code space.  Ah well,
  // it's for a fun cosplay thing, not a cure for rocket surgery.
  if(nextAction == 1)      nextMode();
  else if(nextAction == 2) fire();
// Set ring colors for the next transition
void setTargetColor(
 uint8_t r,       int16_t h,          // Ring index, hue
 uint8_t sPeak  , uint8_t  vPeak,     // Saturation & value @ peak
 uint8_t sTrough, uint8_t  vTrough) ; // Saturation & value @ trough
  uint32_t cPeak   = hsv2rgb(h, sPeak  , vPeak),   // Color @ peak
           cTrough = hsv2rgb(h, sTrough, vTrough); // Color @ trough
  ring[r].color[1][0][0] = cPeak   >> 16;
  ring[r].color[1][0][1] = cPeak   >>  8;
  ring[r].color[1][0][2] = cPeak;
  ring[r].color[1][1][0] = cTrough >> 16;
  ring[r].color[1][1][1] = cTrough >>  8;
  ring[r].color[1][1][2] = cTrough;
// Set ring speed for the next transition
void setTargetSpeed(uint8_t r, int16_t s) ;
  ring[r].spd[1]  = s;
  ring[r].peak[1] = (s > 0) ? 48 : 208;
// Begin transition
void startInterp(uint8_t n) ;
  interpFrames  = n;
  interpolating = n;
// Fixed-point colorspace conversion: HSV (hue-saturation-value) to RGB.
uint32_t hsv2rgb(int16_t h, uint8_t s, uint8_t v) ;
  uint8_t n, r, g, b;
  // Hue circle = 1530 circumference (NOT 1536!)
  h %= 1530;           // -1529 to +1529
  if(h < 0) h += 1530; //     0 to +1529
  n  = h % 255;        // Angle within sextant; 0 to 254 (NOT 255!)
  switch(h / 255) {    // Sextant number; 0 to 5
   case 0 : r = 255    ; g =   n    ; b =   0    ; break; // R to Y
   case 1 : r = 254 - n; g = 255    ; b =   0    ; break; // Y to G
   case 2 : r =   0    ; g = 255    ; b =   n    ; break; // G to C
   case 3 : r =   0    ; g = 254 - n; b = 255    ; break; // C to B
   case 4 : r =   n    ; g =   0    ; b = 255    ; break; // B to M
   default: r = 255    ; g =   0    ; b = 254 - n; break; // M to R
  uint32_t v1 =   1 + v; // 1 to 256; allows >>8 instead of /255
  uint16_t s1 =   1 + s; // 1 to 256; same reason
  uint8_t  s2 = 255 - s; // 255 to 0
  return ((((((r * s1) >> 8) + s2) * v1) & 0xff00) << 8) | // MAF!
          (((((g * s1) >> 8) + s2) * v1) & 0xff00)       |
         ( ((((b * s1) >> 8) + s2) * v1)           >> 8);
ISR(TIMER1_OVF_vect) ; // Timer/Counter 1 overflow, configured for ~30 Hz
  uint8_t  i, r, y, l, x8;
  uint16_t ps, ts, x, xinc, n;
  // Refresh the strip with results calculated during the -prior- frame.
  // Ensures a uniform frame rate; calc time for each frame may vary.
  strip.show();
  for(r=0; r<N_RINGS; r++) {  // For each ring...
    l   = ring[r].firstLED;   // l = current LED index
    x   = ring[r].phase;      // x = ring rotation (65536 = 360 degrees)
    xinc = (uint16_t)(65536L * ring[r].reps / ring[r].nLEDs);
    for(i=0; i<ring[r].nLEDs; i++, x += xinc) { // Each LED on current ring...
      x8 = x >> 8;
      y = (x8 < ring[r].peak[2] ) ?             // Which side of triangle wave?
        (       (uint16_t)x8  * 255) /        ring[r].peak[2] : // Rising edge
        ((256 - (uint16_t)x8) * 255) / (256 - ring[r].peak[2]); // Falling edge
      // y is blending factor (0-255) between peak & trough colors
      ps = y + 1;    // Peak color scale factor (1-256)
      ts = 257 - ps; // Trough color scale factor (1-256, inverse of peak)
      // Blend peak & trough RGB, process through gamma correction table
      strip.setPixelColor(l++, // and store resulting color
        pgm_read_byte(&gamma8[(ring[r].color[2][0][0] * ps +
                              ring[r].color[2][1][0] * ts) >> 8]),
        pgm_read_byte(&gamma8[(ring[r].color[2][0][1] * ps +
                              ring[r].color[2][1][1] * ts) >> 8]),
        pgm_read_byte(&gamma8[(ring[r].color[2][0][2] * ps +
                              ring[r].color[2][1][2] * ts) >> 8]));
    ring[r].phase += ring[r].spd[2]; // Rotate ring for next frame
  if(interpolating) { // Frame-to-frame speed & color interpolation
    if(!--interpolating) { // Interpolation target reached?
      // Set current & prior color & speed to target values
        for(x=0; x<2; x++) {
          for(i=0; i<3; i++) {
            ring[r].color[2][x][i] = ring[r].color[1][x][i];
            ring[r].color[0][x][i] = ring[r].color[1][x][i];
        ring[r].spd[2]  = ring[r].spd[0]  = ring[r].spd[1];
        ring[r].peak[2] = ring[r].peak[0] = ring[r].peak[1];
    } else {
      n = 257 - (((uint16_t)interpolating << 8) / interpFrames);
        ring[r].spd[2] = ring[r].spd[0] +
          (((uint32_t)(ring[r].spd[1] - ring[r].spd[0]) * n) >> 8);
        ring[r].peak[2] = ring[r].peak[0] +
          (((uint32_t)(ring[r].peak[1] - ring[r].peak[0]) * n) >> 8);
        for(x=0; x<2; x++) {     // Wave peak, trough
          for(i=0; i<3; i++) {   // R,G,B
            ring[r].color[2][x][i] = ring[r].color[0][x][i] +
              (((ring[r].color[1][x][i] - ring[r].color[0][x][i]) * n) >> 8);
const uint8_t PROGMEM
 gamma8[] = { // x^2.8 improves appearance of midrange colors
    0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,
    0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  0,  1,  1,  1,  1,
    1,  1,  1,  1,  1,  1,  1,  1,  1,  2,  2,  2,  2,  2,  2,  2,
    2,  3,  3,  3,  3,  3,  3,  3,  4,  4,  4,  4,  4,  5,  5,  5,
    5,  6,  6,  6,  6,  7,  7,  7,  7,  8,  8,  8,  9,  9,  9, 10,
   10, 10, 11, 11, 11, 12, 12, 13, 13, 13, 14, 14, 15, 15, 16, 16,
   17, 17, 18, 18, 19, 19, 20, 20, 21, 21, 22, 22, 23, 24, 24, 25,
   25, 26, 27, 27, 28, 29, 29, 30, 31, 32, 32, 33, 34, 35, 35, 36,
   37, 38, 39, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50, 50,
   51, 52, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 66, 67, 68,
   69, 70, 72, 73, 74, 75, 77, 78, 79, 81, 82, 83, 85, 86, 87, 89,
   90, 92, 93, 95, 96, 98, 99,101,102,104,105,107,109,110,112,114,
  115,117,119,120,122,124,126,127,129,131,133,135,137,138,140,142,
  144,146,148,150,152,154,156,158,160,162,164,167,169,171,173,175,
  177,180,182,184,186,189,191,193,196,198,200,203,205,208,210,213,
  215,218,220,223,225,228,231,233,236,239,241,244,247,249,252,255 };
Re: code error
I see several major issues. First of all, an Arduino program must have exactly one setup() and one loop(). It looks like you are trying to define a second loop() function.
Also, many of your function definitions do not follow valid C syntax. You need to have balanced curly braces to define the scope of the function.
https://www.arduino.cc/en/Reference/FunctionDeclaration
Johnathan_hoang
Re: code error
I am new to coding and didn't understand what you just said the code that i found was just copied and pasted from the learn.adafruit.com website
   Hulkbuster Unibeam sketch for Adafruit Gemma & NeoPixels.
   Requires one 16-pixel NeoPixel ring, one 24-pixel ring, and six single
   NeoPixels arranged in a large circle.  Gemma pin D1 connects to the 24-
   pixel ring first, then the 6-pixel, then 16...but the physical
   'stacking order' is 6 (bottom), then 24, then 16 (top).  Add momentary
   buttons between D1 & GND (mode) and D2 & GND (fire).
   Unfortunately this ended up resembling an obfuscated C contest entry,
   and beginners reading it probably won't gain much besides a headache,
   but I'll comment as best I can.  The code is trying to generate some
   very fluid animation (I don't care for 8-bit-looking twitchy blinky
   stuff) on a very limited microcontroller (about 5K flash space and no
   multiply instruction) and thus relies heavily on fixed-point math
   (using the most-significant digits of large integers to approximate
   the handling of fractions).  Ran out of space toward the end, so parts
   (like button handling) are a bit slipshod...working but not great.
   The core idea is that each NeoPixel ring depicts a triangle wave,
   the phase (rotation) and other parameters can be adjusted on a
   subpixel basis so it's all buttery smooth.  There may be some number
   of repetitions of the wave (always integer) around the circumference
   of the ring...for example, as written, it's 3, 4 and 2 reps for the
   center (16), middle (24) and outer (6 pixel) rings, respectively.  If
   the circles were 'unrolled,' the waves might resemble:
   Each ring then has different colors corresponding to the 'peaks' and
   'troughs' of these waves.  Those colors change over time...but never
   just an abrupt reassignment, there's always a smooth transition from
   one set of colors to the next.  Other parameters, like rotation phase
   and speed, are also interpolated smoothly through those transitions.
   Oh, also, there's timer interrupts, another really complicated subject.
   Sorry about that.
#endif
  ring(30, 16, 3)  \
  ring( 0, 24, 4)  \
  ring(24,  6, 2)  \
struct Ring {
} ring[] = {
struct Mode {
  const int16_t hue;
} modeData[] = {
uint8_t
  mode       = 0,
volatile uint8_t
#endif
  strip.begin();
 #else                                        // 8 MHz:
 #endif
#endif
void waitForButtonRelease() {
void setRingsToIdleValues() {
void nextMode() {
void fire() {
  uint8_t r;
    } else {
 uint8_t sTrough, uint8_t  vTrough) { // Saturation & value @ trough
void setTargetSpeed(uint8_t r, int16_t s) {
  ring[r].spd[1]  = s;
// Begin transition
void startInterp(uint8_t n) {
  interpFrames  = n;
  interpolating = n;
uint32_t hsv2rgb(int16_t h, uint8_t s, uint8_t v) {
  uint8_t n, r, g, b;
ISR(TIMER1_OVF_vect) { // Timer/Counter 1 overflow, configured for ~30 Hz
  strip.show();
      x8 = x >> 8;
    } else {
Re: code error
You can't just paste two Arduino sketches together. You can only have exactly one setup() and exactly one loop().
Here is an article that describes how two sketches can be combined.
https://arduinogetstarted.com/faq/how-t ... o-sketches
Johnathan_hoang
Re: code error
Thank you for the previous post as i didn't realize you have to delete original setups and loops when opening new sketch if copying in a new code
Return to “Arduino”
