Hello, I am using this component: https://learn.adafruit.com/adafruit-vem ... t?view=all
What is the maximum value I can get? I am confused by what the datasheet describes about that... Can you help me?
VEML6070 maximum value
- adafruit_support_carter
Re: VEML6070 maximum value
Do you mean what is the maximum value you'll get back from some library function call? If so, what library are you using?What is the maximum value I can get?
Or do you want to know what the max range of the sensor is? For that, look in the datasheet:
https://learn.adafruit.com/adafruit-vem ... /downloads
- giorgio_new
Yes I mean what is the min and max values I can get from the library function call...? I use the Adafruit library.
The reading is returned as a 16 bit unsigned integer, so possible value range is 0 to 65535.
- giorgio_new
Ok, but here: https://cdn-learn.adafruit.com/assets/a ... ml6070.pdf it says: 5 steps per μW/cm^2/step. So 65535/5 = 13107 μW = 13 mW, but the datasheet says maximum optical power = 328 mW... What I miss here?
That's the possible range for the sensor. You may not see the full range of a uint16_t (what the library returns) due to actual physical limits of the sensor. That's the sort of information you'd get from the datasheet.
