Hi all, Anyone ever get prototmatter to work with RP2040 connect board? I am getting a bunch of errors when I try to use it. I had it working fine on a mkrwifi1010 connect board but ran out of memory - so I upgraded to RP2040connect board. All the other parts of my code run, but when I try to include the protmatter, I get weird errors like this:
C:\Users\richa\Documents\Arduino\libraries\Adafruit_Protomatter\src\core.c: In function '_PM_begin':
C:\Users\richa\Documents\Arduino\libraries\Adafruit_Protomatter\src\core.c:312:32: error: '_PM_timerFreq' undeclared (first use in this function); did you mean '_PM_timerStop'?
uint32_t minPeriodPerFrame = _PM_timerFreq / _PM_MAX_REFRESH_HZ;
_PM_timerStop
C:\Users\richa\Documents\Arduino\libraries\Adafruit_Protomatter\src\core.c:312:32: note: each undeclared identifier is reported only once for each function it appears in
exit status 1
Error compiling for board Arduino Nano RP2040 Connect.
Seems like there are some things missing in the #defines.
I am using the deprecated MBED OS boards package - if I use the non-deprecated one it prevents downloading of even the blink sketch.
Thanks for any suggestions!
Protomatter with arduino RP2040 connect
- mikeysklar
Re: Protomatter with arduino RP2040 connect
It looks like the Adafruit_Protomatter library has support for the rp2040.
https://github.com/adafruit/Adafruit_Pr ... 2040.h#L74
I suspect this would work fine on a Pico Pi or Feather RP2040. I wonder if your board is being identified correctly being an Arduino Nano based RP2040.
- adafruit2
we only support the philhower core for rp2040, you may want to ask arduino to help add support for their core
- richardhampo
Hi - can you please elaborate? I do not understand your comment about the core and why it is not supported? Are there any modifications I can make to the library to get it to compile and work?adafruit2 wrote:we only support the philhower core for rp2040, you may want to ask arduino to help add support for their core
Thank you!
- richardhampo
Hi Mikey,mikeysklar wrote:It looks like the Adafruit_Protomatter library has support for the rp2040.
I thought there was something missing also in the board ID so I did #define of __RP2040__ and then got further errors. I did more #defines and got further and further down the rabbit hole.... It is a bit frustrating because I got a whole application working on a MKR1010 but ran out of memory to run a 3 wide 64x32 display. So that is why I got a RP2040 - it has 256kb SRAM.
There must be something I can do to fix the compile errors.
Alternately - do you know of any other arduino compatible display libraries that work with multiple displays?
Thanks!!
Richard
- mikeysklar
Richard,
If you would like to use an RP2040 based board it will have to be one listed in philhower’s supported boards:
https://github.com/earlephilhower/ardui ... ted-boards
I would recommend using a Feather RP2040.
If you want to experiment with multiple RGB panels (chaining) you can take a look at these guides. The first uses our RGBMatrix library. The second links for using a MatrixPortal setup.
https://learn.adafruit.com/rgb-led-matr ... g-of-BANNED
https://learn.adafruit.com/rgb-led-matr ... ple-panels
- adafruit2
yah there are two 'cores' for rp2040 - the arduino official one (for their boards) and the philhower core (for everyone elses!) - right now protomatter only supports the latter. arduino could add support for their core into protomatter if they have time!
- richardhampo
Hi Mikey, The list for the pico supported boards you mentioned includes the nano RP2040 connect that I am using. I loaded that board package and selected nano RP2040 connect board but get even more compile errors. I am not familiar with the feather boards - but I need lots of SRAM and wifi chip, and ability to have EEPROM (I use serial EEPROM on I2C now).mikeysklar wrote:Richard,
I will look at the RGBmatrix library and matrixportal and see if I can extend to wider display. THanks for your comments and assistance!
- richardhampo
Hi,adafruit2 wrote:yah there are two 'cores' for rp2040 - the arduino official one (for their boards) and the philhower core (for everyone elses!) - right now protomatter only supports the latter. arduino could add support for their core into protomatter if they have time!
I loaded the arduino board package for philhower cores - (https://learn.adafruit.com/rp2040-ardui ... hower-core)
and none will compile the protomatter display test program without bunches of errors. Is this expected? I tried plain RPI pico, feather 2040, and several others. I thought that the philhower package would make protomatter compile properly. Any thoughts?
I really don't want to have to rewrite my program from C to python to use the circuit python RGB matrix library, I am an old school C guy.
I am really bummed that I cannot find a way to get simple text to show on RGB matrix with the RP2040 connect board. Any wild ideas?
Thanks for your continued suggestions.
- adafruit2
ooh oops it actually doesnt work in arduino - not sure if it ever did tbh - it only works in raspberry pi at this time. not sure what it would take to get it in arduino. your best bet with the hardware is to go for circuitpython!
