I am able to operate the Adafruit Music maker shield with an Arduino Uno . I am playing music with the Player_Simple Program. I replaced the Arduino Uno with an Arduino Uno Wifi Rev 2 and when it runs I get a the message: Couldn't find VS1053, do you have the right pins defined?
I was hoping it was an easy swap!
Help
using Music maker with Arduino Wifi Rev 2
- rpiloverbd
Re: using Music maker with Arduino Wifi Rev 2
I have not used Arduino Uno Wifi Rev 2, but I am sure your problem exists in the numbering of the SPI pins. In the products page ( https://www.arduino.cc/en/Guide/ArduinoUnoWiFiRev2 ) , it says "The IMU and the WiFi module are connected to the SPI bus and have individuale and dedicated pins for Chip Select (CS)". You can get some clues here too: https://forum.arduino.cc/t/help-on-spi- ... v-2/689905
- rlh001
I've gone through a lot of the literature and did not find pins used for SPI bus to be different from Standard Uno and Uno Wifi !!??
Has anyone been able to make the Adafruit Music Maker shield work with an Arduino Uno Wifi Rev 2??
