Adafruit_Neopixel fill() Function Help
savall21
Post by savall21 »
I'm trying to use the Adafruit_Neopixel fill() function to light two separate segments of the Neopixel strip. It looks like I'm doing something wrong with the color input. The second fill command is working but not the first. Can someone tell me the correct syntax?
#define LED_COUNT 129
#define LED_PIN A4
Adafruit_NeoPixel strip(LED_COUNT, LED_PIN, NEO_GRB + NEO_KHZ800);
  strip.begin();
  strip.fill((255, 0, 0), 1, 10);
  strip.fill((0, 0, 255), 20);
  strip.show();   // Send the updated pixel colors to the hardware.
Re: Adafruit_Neopixel fill() Function Help
It is not clear how many pixels you want to fill in your second call. Replace 'n' with the number of pixels to fill.
  strip.fill(strip.color(255, 0, 0), 1, 10); // fill 10 pixels with RED - starting at pixel 1.
  strip.fill(strip.color(0, 0, 255), 20, n);  // fill 'n' pixels with with BLUE - starting at pixel 20
savall21
Post by savall21 »
The Adafruit NeoPixel Überguide states that if you omit the count argument it shill fill from listed input to the last. So I'm trying to go from 20 to the last pixel.
https://learn.adafruit.com/adafruit-neo ... ibrary-use
"If called without a count argument (only color and first), this will from first to the end of the strip."
Do you know what syntax is for inputing the color?
The omitted argument does default to zero as you can see in the header file:
https://github.com/adafruit/Adafruit_Ne ... NeoPixel.h
  void fill(uint32_t c = 0, uint16_t first = 0, uint16_t count = 0);
But you are correct, the code interprets a 0 as 'fill to the end of the strip'.
See the code from my previous post.
Return to “Arduino”
